Thread: Vibration help
Results 1 to 18 of 18
  1. #1 Vibration help
    SE Level Member bowtie racer's Avatar
    Jun 2010
    Kansas City
    About 3 days ago I got a vibration in the front end. I really feel it at 1/4 throttle at as low as 30 mph and higher speeds. When I let off the the throttle it goes away. It almost feels like a loose pulley(I checked them and they seem fine). I checked the motor mounts and they seemed ok. At first I thought it was a loose wheel or one out of balance or even a wheel bearing, but I ruled that out since it goes away when i'm not giving it any throttle and its not making any noise. The other thought that I keep having is a cv joint (not sure which side) although there is no vibration when turning.
    Seems like that has been many peoples problem with similar symptoms when I did a search. Any ideas or suggestions? I would appreciate it.
  2. #2 Re: Vibration help
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    cv axles bro, mine does it too but from 35-50
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  3. #3 Re: Vibration help
    Banned
    Apr 2011
    wv
    mine does this but its because my torque converter isnt locking up and it really only does it at highway speeds with slight throttle. ive had 2 other automatics with bad converters that made the front end wobble. both were RWD
  4. #4 Re: Vibration help
    Nov 2010
    south east AZ
    Not trying to be a dick but if you know the answer to your problem then why post the question? I've heard of suspension components, drive line components, and wheel bearing causing front end vibrations, but not a torque converter that is new to me. Usually when your accelerating and there is a wobble then let off the gas and it goes away, the most common problems are u joints going out, RWD, or a cv joint going out, FWD.
    01 T/A WS6-SOLD
  5. #5 Re: Vibration help
    Nov 2010
    south east AZ
    My bad L36, I thought you were the OP posting the answer to your own question, I apologize
    01 T/A WS6-SOLD
  6. #6 Re: Vibration help
    Banned
    Apr 2011
    wv
    thats ok dude. and i had a chevy van with a 350. the converter wouldnt lock up and the whole front end whobbled like crazy. i thought the mechanic was BSing me when he told me but it was no lie. i also had an 81 bonneville with a 5.0 that did the same thing. i did a trans swap and the engine wouldnt communicate with the lock up converter for some reason. bad wiring or something.
  7. #7 Re: Vibration help
    Nov 2010
    south east AZ
    Wierd. Learn something new everyday with cars
    01 T/A WS6-SOLD
  8. #8 Re: Vibration help
    Banned
    Apr 2011
    wv
    yeah, i would love to get an explenation as to WHY it does that.
    nice coupe btw. red is gonna be my next gp.
  9. #9 Re: Vibration help
    Nov 2010
    south east AZ
    Thanx, it has its issues right now which I'm trying to work out. Its a work in progress. I'm trying to restore its former glory while at the same time making it better and faster. I have a thread up of the car under members rides, nick name SLPR DD
    01 T/A WS6-SOLD
  10. #10 Re: Vibration help
    Banned
    Apr 2011
    wv
    grand prixs arent for the mechanicaly uninclined, but if you fix them right theyre such good cars. mine is a BOSS in the snow, which is the main reason i havent switched to something with a v8, thats easier to go fast.
  11. #11 Re: Vibration help
    Nov 2010
    south east AZ
    ya its lil things here and there that when i get one thing fixed another thing goes wrong. before it was a misfire, turns out the coil for that cylinder was at first had low output voltage then quit altogether. got that fixed and literally a week later its running like crap again with horrible gas mileage and cant exceed 40-50% throttle and it starts chugging with a DTC code, so ive been troubleshooting that for about a month now..................little things
    01 T/A WS6-SOLD
  12. #12 Re: Vibration help
    Banned
    Apr 2011
    wv
    multiple missfires? mines the same way but its soooo worth the effort to keep it repaired. catalytic converters can get clogged, the coil packs can all go bad.
    btw autozone can test your coil packs and your ignition control module. use an ohm meter on the coil packs. should be between 5k and 12k ohms.
  13. #13 Re: Vibration help
    Donating Users Ca5p21x's Avatar
    Jun 2011
    Sacramento, California
    yo, I too am having issues with vibration. (2000 GRAND PRIX GTP 170,000)
    Once i reach speeds of 50mph on the highway the vibrations start. AND like Bowtie, once i let of the gas it goes away.Seems to be comming from my front end. I am taking it in tomorrow to get the front end checked and an alignment. Will post my results tomorrow. Thanks
  14. #14 Re: Vibration help
    Topeka, KS
    Mine was like yours Ca5p21x and it was the tires that were out of balance. Had them balanced and rotated and it fixed the problem.
  15. #15 Re: Vibration help
    Jun 2011
    Quote Originally Posted by rynoman03 View Post
    Hey Bro, thanks for the heads up. Im actualy waiting untill friday to get it taken care of. I orderd new lug nuts and wheel locks so im gonna get it all taken care of then. Will Post my finding, Thanks agian
  16. #16 Re: Vibration help
    Jun 2010
    Kansas City
    I forgot to give an update. I ended up replacing the cv shaft, a wheel bearing, and a new tie rod. Solved everything.
  17. #17 Re: Vibration help
    Jun 2011
    So I have an update on my vibrating issue. I have three horrible tires. One tire is even cupped. Brutal right Suspension checked out cool I.E. Control arm, ball joint, bushings, wheel hub/Bearing, Axle Shaft So have all your tires checked and balanced and see if that fixes your issue.
  18. #18 Re: Vibration help
    SE Level Member 1fastgtp's Avatar
    Jun 2011
    Lewiston
    that would defently cause the vibration.
    2000 Grand Prix GTP: Modifications: SLP catback exhaust-SLP Headers- 180 Termostat- wizaired cold air intake-PRJ 10.4mm wires- autolite 104's- zzp tune- full size intercooler- vs cam- 3.0" pulley ETC. Fastest Grocery Gitter in town
  1. Vibration
    By Klutch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-26-2009, 02:52 PM
  2. Odd Vibration
    By VGPGT in forum General Tech Discussion
    Last Post: 04-15-2009, 04:18 PM
  3. vibration
    By david hagaman in forum General Tech Discussion
    Last Post: 04-11-2009, 11:16 AM
  4. Vibration
    By silvertip in forum General Tech Discussion
    Last Post: 04-09-2009, 09:09 AM
  5. vibration
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2008, 05:24 AM
