multiple missfires? mines the same way but its soooo worth the effort to keep it repaired. catalytic converters can get clogged, the coil packs can all go bad.
btw autozone can test your coil packs and your ignition control module. use an ohm meter on the coil packs. should be between 5k and 12k ohms.
