About 3 days ago I got a vibration in the front end. I really feel it at 1/4 throttle at as low as 30 mph and higher speeds. When I let off the the throttle it goes away. It almost feels like a loose pulley(I checked them and they seem fine). I checked the motor mounts and they seemed ok. At first I thought it was a loose wheel or one out of balance or even a wheel bearing, but I ruled that out since it goes away when i'm not giving it any throttle and its not making any noise. The other thought that I keep having is a cv joint (not sure which side) although there is no vibration when turning.
Seems like that has been many peoples problem with similar symptoms when I did a search. Any ideas or suggestions? I would appreciate it.
