Thread: Driver Information Center - No lights, Any suggestions??...Please help
Results 1 to 20 of 27
  1. #1 Re: Driver Information Center - No lights, Any suggestions??...Please help
    May 2011
    FL
    I have the same problem bud, bought my 99 gtp with the DIC not working, it annoys the hell outta me. Ill update if i find my issue but ive tried all the basic things you would think of.
  2. #2 Re: Driver Information Center - No lights, Any suggestions??...Please help
    GT Level Member Tea Time's Avatar
    New Brunswick
    Thanks man, let me know....i'm gonna tear my car apart and follow each individual wire from the dic in hopes that i find a bad wire
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  3. #3 Re: Driver Information Center - No lights, Any suggestions??...Please help
    New Brunswick
    Codester... just wonderin if ur dic is still workin after the ignition saver mod?
    I still haven't tore apart my car to chase all the wires... so its still not working
    '97 GTP - Project
  4. #4 Re: Driver Information Center - No lights, Any suggestions??...Please help
    New Brunswick
    Well....finally some resolution to this thread, i have finally fixed my dic.
    I had a couple days off so i decided to tear the dash out of my car and start chasing wires and checking fuse panels incase a wire fell out or broke...anyways this is dash out (day 1)...
    so i chased each wire into each harness inside the cabin, checked where they plugged into the fuse panel and all was good, tight and no breaks in wires.i even started a thread to find out how many live wires should run to a working DIC but got no replies....i figured if someone had 5 live wires to a working dic then i would concentrate on a certain wire but there only supposed to b 4 live wires to the dic (which i had). so i took the dic apart while still plugged into the car so the bulbs were exposed...now i had my test light grounded to the frame of the car and started touching the circuits inside the dic with the test light (i was just frustrated and bored at this point which is why i started poking at the dic with the test light).
    BAM...all of a sudden i touched a point on the circuit board and the dic lit up but didn't display any numbers....so i brought the dic inside my house and tore it apart...to find this...
    a resistor or some thing of the sort on the corner of the dic burned up causing the DIC not to work.....So a long story ; short .... my DIC was defective , i assumed it was fine and the problem was wiring
    Day 2 - Ran to the junkyard today, got one and it now works...installed my dash and everything now works....sucks that i took the entire dash out but gave me a chance to install the HUD, that the car didn't have for some odd reason.
    '97 GTP - Project
  5. #5 Re: Driver Information Center - No lights, Any suggestions??...Please help
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    Quote Originally Posted by Tea Time View Post
    From hindsight, I wish I would have taken my dash out to do the HUD install. Trying to make the cuts and not hit the windshield was a major PITA. Don't even get me started on the mess.
  6. #6 Re: Driver Information Center - No lights, Any suggestions??...Please help
    New Brunswick
    tdm...u nik ur windshield at all?
    I assumed everyone changed dashes too when installing hud but when i had both dashes side by side, the without dash just needed to be cut and everything else was there to install hud, so i wondered if guys left the dash in to cut it or took it out. (i didn't read anything about the hud install before i started, just went with it}
    '97 GTP - Project
  7. #7 Re: Driver Information Center - No lights, Any suggestions??...Please help
    On Regals, I chop in the car.
  8. #8 Re: Driver Information Center - No lights, Any suggestions??...Please help
    Lakeside Park, KY
    I did nik it once. Not bad, but still got it.
  1. Dim Driver Information Center
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 02-13-2012, 09:25 PM
  2. driver information center
    By bc1 in forum General Tech Discussion
    Last Post: 12-12-2010, 10:21 AM
  3. Driver Information Center
    By techn9cian99GTP in forum Audio, Security & Visual Electronics
    Last Post: 12-12-2010, 10:02 AM
  4. Driver information center
    By sbrutcher in forum Introductions/Noob Questions
    Last Post: 02-13-2010, 03:20 PM
  5. driver information center
    By Green Machine in forum General Tech Discussion
    Last Post: 08-05-2008, 12:14 AM
