Thread: Fuse door
Results 1 to 4 of 4
  1. #1 Fuse door
    Michigan
    How does one get the fuse box door open that is on the passenger side of the dash panel? I've tried pulling, pushing, moving back and forth... it won't budge! Is there a trick to it? This is the one that faces the door on an 05.
  2. #2 Re: Fuse door
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    You just got to muscle it out by pulling on it. The first couple of times will be hard but once you pop it in and out couple times it gets easier.
  3. #3 Re: Fuse door
    Waukesha, WI
    once you get it off, leave it off
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  4. #4 Re: Fuse door
    Michigan
    Yep. Youre right. I actually had to reach in and press on the barbs with a small screw driver to get it to come off. I was afraid I was going to rip the dash board.
    Thanks,
    Scott
  1. HELP HELP! 99 grand prix 2 door DOOR HINGE REPLACEMNT
    By blortz in forum General Tech Discussion
    Last Post: 05-31-2011, 08:52 PM
  2. Big 3 fuse
    By c32k05 in forum Audio, Security & Visual Electronics
    Last Post: 04-21-2009, 02:06 PM
  3. door locks/BCM/speaker/ door question
    By adamlesandrini in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2009, 05:14 PM
