Thread: Aeroforce gauge...
Results 1 to 18 of 18
  1. #1 Aeroforce gauge...
    GT Level Member duane9586's Avatar
    Apr 2008
    ny
    I finally got my aeroforce gauge ( it only took 14 days to ship) I installed it last night and i was wondering what you guys think i should monitor. I had up trans temp and kr. The kr never changed stayed at 0.0, is that right? How acurate is the hp and torque? TIA
    Ok now that i have played around with it i noticed that my KR is actually up to 4.2. I need to get rid of that
    180*, Overkill, K&N, MSD, GEN V, AL 104's,ZZP Shift kit,SD Headers,1.9rr's, 90#,3.2zzp,0KR, 8K HID,Was a Base Model
  2. #2 Re: Aeroforce gauge...
    Barksdale AFB, LA
    Quote Originally Posted by duane9586 View Post
    That means you're not getting knock, which is good. If you were just cruising, then that's normal. Knock usually occurs during WOT.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Aeroforce gauge...
    Apr 2008
    ny
    Quote Originally Posted by Sabrewings View Post
    I will go and get on it again but last night i ran it at wot for 1/8 mile and i didn't notice any but i will try again to be sure
  4. #4 Re: Aeroforce gauge...
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    I didn't know the non supercharged 3.8's were that prone to KR.
    I posted this on clubgp to your post, but I ordered my Aeroforce on June 9th, and still have not received it yet. Marylandspeed, where I ordered it from, sent me an email yesterday, telling me Aeroforce lost my order.
    Anyway KR (supercharged and LTFT will be what I monitor, but will swap LTFT for soemthing else if a problem needs to me tracked down.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  5. #5 Re: Aeroforce gauge...
    Apr 2008
    ny
    Quote Originally Posted by IndeedSS View Post
    thanks, i got mine from zzp
  6. #6 Re: Aeroforce gauge...
    Barksdale AFB, LA
    I ordered straight through Aeroforce.
    As for knock, I'm having trouble getting my tune right to get rid of knock while in PE. Other than that it's good.
    I use the cyclic scan and have a lot of values in there. For knock, I set the annunciator lights to go off at 3* or more.
  7. #7 Re: Aeroforce gauge...
    Apr 2008
    ny
    Ok I monitored my KR and trans temp last night...
    1. KR saw 0.5 at WOT in 1st and 2.1 at WOT in 2nd
    2. Trans temp saw a high of 181*
    Are these acceptable #'s
  8. #8 Re: Aeroforce gauge...
    St Louis MO
    I don't like to see any KR, but those numbers seem good to me. You can probably have the rest of the KR tuned out, if you wanted.
    2010 Camaro SS LS3
  9. #9 Re: Aeroforce gauge...
    Apr 2008
    ny
    If I only had a tuner
  10. #10 Re: Aeroforce gauge...
    Donating Users blowfishRus6's Avatar
    g.a.
    trans temps seem fine. messureing by the hud in my car. (i guess its accurate) in the summertime they can get up to 220+. usally around 215. i thought that was normal..
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  1. Fuel Gauge
    By agent505 in forum General Tech Discussion
    Last Post: 05-06-2010, 11:07 AM
  2. scangauge II vs. aeroforce interceptor
    By kyle99gtp in forum General Tech Discussion
    Last Post: 06-25-2008, 09:48 PM
  3. Using the Oil Life Gauge
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2008, 09:26 AM
