Thread: Using the Oil Life Gauge
Results 1 to 13 of 13
  1. #1 Using the Oil Life Gauge
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    Does this show the actual resistance of the oild or does it just show milage and do people use this for Oil changes
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  2. #2 Re: Using the Oil Life Gauge
    Barksdale AFB, LA
    It uses a formula based off RPMs, engine temperature, engine load, and various other parameters to calculate the breakdown and contamination of the oil. It relies on you to reset it when the oil is changed.
    GM did a LOT of research (meaning, lots of money) on this with oil analysis to program the OLM and it works surprisingly well. Knowing what I know now about how much GM went through and how accurate it can be, I would not have an issue going until the OLM said the oil is bad. I reset it every time I change the oil.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Using the Oil Life Gauge
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    and gms oil system is one the best out there. i change mine when it gets to about 30%
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  4. #4 Re: Using the Oil Life Gauge
    PA
    Quote Originally Posted by Sabrewings View Post
    So knowing this, when do you recommend to change the oil? When the monitor gets to 0%?
    I change mine every 3k miles and the OLM is around 65-70%.
    2001 GSE
  5. #5 Re: Using the Oil Life Gauge
    Barksdale AFB, LA
    Quote Originally Posted by Zef_66 View Post
    To be honest, I'm not sure. On the Impala (well, 00-05 models) you can't view the percentage left. It just comes up one day on the message center and says "Change oil Soon". However, if I could see the percentage, I'd be comfortable getting in the 15-25% range.
  6. #6 Re: Using the Oil Life Gauge
    Oklahoma
    I agree with Sabrewings. the GM OLM was one thing they did engineer well and is accurate. I usually reset mine at 0%. When it hits 0, I get an oil sample and send it in for analysis and keep on truckin' until the oil analysis says its time to be changed. That usually happens between 7500 - 8000 miles.
  7. #7 Re: Using the Oil Life Gauge
    GTP Level Member David99GTP's Avatar
    Florida
    I change mine 3k or less no matter what it says. On all my vehicles I change it when it begins to look dirty even if its less than 3k. I never go over 3k. I had a 1991 3.1L lumina go 275k, a 93 3/4 ton chevy work truck go 400k and neither had any major repairs. So I'm a believer Changing too often can do no harm, and probably contributed to my engine's longevity.
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  8. #8 Re: Using the Oil Life Gauge
    Barksdale AFB, LA
    Quote Originally Posted by David99GTP View Post
    That's very wasteful. Just because the oil is dark doesn't mean it's "dirty". It's doing its job of trapping and suspending carbon, which a good oil will start to turn dark in the first few hundred miles.
    Motor Oil Myths and Facts
    Changing oil does help, but changing it at 3k isn't going to make a difference over 5k (or more) if you're using a quality oil.
  9. #9 Re: Using the Oil Life Gauge
    Oklahoma
    I ran across a study a couple years ago that indicated that after an oil change, wear actually spiked. In other words, wear went up initially then settled. I havent seen any follow up studies yet but if it were to pan out and wear particles do actually increase initially after an oil change, then that would mean there could be 'some' harm in changing it too often.
  10. #10 Re: Using the Oil Life Gauge
    Naugatuck CT
    If you use synthetic over convetional will the Car take that in to consideration when telling you the % of life left
  11. #11 Re: Using the Oil Life Gauge
    Barksdale AFB, LA
    Quote Originally Posted by jacobmh27 View Post
    It has no way of telling the difference.
  12. #12 Re: Using the Oil Life Gauge
    May 2008
    McHenry IL
    i stay on the safe side and change mine every 2800 to 3000 miles with synthethic mobil 1 or penzoil i think. good expensive stuff lol. how do u reset the oil gauge i took my battery cables of a few days ago to put my stereo and stuff in and the computer was loopy then it started getting back to normal like the mileage left in the tank and the mpg stuff. the oil gauge do u just hit reset?
  13. #13 Re: Using the Oil Life Gauge
    PA
    To reset the OLM, you need to press and hold the reset for 5 seconds. Or something like that.
    As for oil changes, like I said, I change mine every 3k miles. I don't waste my money on oil analysis or anything. For my DD, that is fine.
    2001 GSE
  1. Why Does My Gas Gauge Not Work?
    By BLACKEDOUTGTP in forum General Tech Discussion
    Last Post: 07-21-2024, 08:19 AM
  2. Gas gauge stuckk
    By 97grandprix4me in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-03-2012, 12:01 PM
  3. GP totalled, life on hold
    By Quicksilver_GP in forum Off Topic Discussion
    Last Post: 05-08-2008, 09:54 AM
  4. oil psi gauge going crazy?
    By Bio248 in forum Off Topic Discussion
    Last Post: 02-02-2008, 06:15 PM
