Thread: Timing problem?
Results 1 to 3 of 3
  1. #1 Re: Timing problem?
    i'd avoid down shifting newer cars, the trans aren't made for that, as a cdl driver the rule of thumb is to lightly hit the brake and slow down 10 mph, let off and roll till you hit the speed limit, and repeat as needed to avoid over heating the brakes, and in a big truck the brakes will heat up real fast and just stop working altogether and thats no damn good. I've applied this to all cars i drive and have have no warping or brake fade at all.
    cant help with the trans problem, im sure someone with trans know how will chime in.
  2. #2 Re: Timing problem?
    MI
    Gotcha, thanks for the advice. Mountains out here in Utah have some pretty steep grades (7+ %) so even if you let off the gas you are definitely going to accelerate. With some of the steep grade sections lasting 10 miles plus it can be pretty rough on the brakes by the time you are out. If I drop it into 2nd on a moderate grade I can maintain the speed limit at a decent RPM without touching my brakes. The front rotors on this car warped not too long after we got here, so I've been leaning more toward engine braking. I guess if it's that bad for my transmission I would much rather replace the brakes/rotors...
  1. Ideal timing
    By 01gpgt01 in forum General Tech Discussion
    Last Post: 09-26-2010, 03:30 PM
  2. N/A Cam timing
    By skidoojames151 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-14-2009, 01:12 AM
  3. Got another timing???
    By GTP4 in forum PCM Tuning
    Last Post: 11-15-2008, 07:38 PM
  4. N/A L67 timing differences with/vs L36?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2008, 12:51 AM
