Thread: No head lights or heat
Results 1 to 9 of 9
  1. #1 No head lights or heat
    MAss
    I just swapped the ignition, blower, and blower motor resistor. What the hell is going on with this thing?? I read that is can be the crank angle sensor but i just wanna make sure before I go and do it.
  2. #2 Re: No head lights or heat
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    ive also heard it could be an ignition switch, but i have the same thing going on with mine but i dont use my heater or a/c so no biggy, but i would like to know what it is. ive heard of a few other ppl having this very same issue but never heard back what it was
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  3. #3 Re: No head lights or heat
    MAss
    Yea i heard that to but i just put in a new one and I live in Mass so we need the heat for the winter but i checked all the fuses and those are good. I cannot pinpont where the problem is. One if the fuses for the climate control doesnt even have power going through it so I dont know where to start on that. I've heard that the Crank sensor goes bad and gives you the headlight problem but could it also have something to do with my Climate control?? Its a 98 GTP by the way with auto climate control.
  4. #4 Re: No head lights or heat
    Apr 2011
    Oregon
    I had the same issue on my 02 GTP. After scouring the wire diagrams the only common circuit location was the ignition switch. I changed that and have not had a problem since.
  5. #5 Re: No head lights or heat
    MAss
    vehicle
    Found that good link with some solid info so im ganna check on it tonight and let u guys know. Maybe a wire came loose from the cut and swap I did.
  6. #6 Re: No head lights or heat
    MAss
    Ok so here's the word, I fixed it and it was exactly what i thought it was. There was a wire that came loose on the ignition switch. Tapped it a couple of time's on the lower stearing colum and it turned on. Bless God, well hopefully this will help someone else out. Oh and it also turned the HUD display withthe MPG,oil lifes, fuel consumption ect ect on cause that shut off aswell.
  7. #7 Re: No head lights or heat
    Nov 2010
    south east AZ
    can you take a pic of it and point it out plz, that would do me a huge favor
    01 T/A WS6-SOLD
  8. #8 Re: No head lights or heat
    MAss
    I got you taman86, I'll try to grab some pics tomorrow. Just to let u know what I did is I grabbed a starter from auto zone cut off the ignition switch part that I needed and I spliced the wires together. Then I returned the old one after I taped it together lol.
    I'll make sure to point out the wires that got loose.
  9. #9 Re: No head lights or heat
    MAss
    Didnt manage to grab a pic but the Orange wire came loose from the crimped wires.
  1. Head lights and dash lights randomly shut off
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-01-2020, 05:45 AM
  2. LED head lights
    By Juanmiguel in forum Audio, Security & Visual Electronics
    Last Post: 01-23-2011, 12:16 PM
  3. Replies: 0
    Last Post: 03-07-2010, 09:14 PM
  4. Replies: 3
    Last Post: 01-16-2010, 07:19 PM
  5. head lights
    By mlinville11 in forum General Tech Discussion
    Last Post: 07-17-2009, 01:23 PM
