Thread: Coolant Change
Results 1 to 4 of 4
  1. #1 Coolant Change
    Jan 2009
    Michigan
    Does anyone know if it is possible to get the coolant switched at an oil change joint by getting a flush. Typically the flush cost about $35 at my place. Can the coolant be switched at this time from dex to the good ole green stuff?
  2. #2 Re: Coolant Change
    Charles City, IA
    If they have a coolant flusher yes they can do it. If not no. A lot of people go from dex to green.
    SMGPFC Two Nipple General
  3. #3 Re: Coolant Change
    Oct 2008
    Northern Illinois
    GET RID OF DEXCOOL NOW.
    I can post some pics of my old heads with dexcool packed in them, all it does is gunk over time and screw your engine.
  4. #4 Re: Coolant Change
    GT Level Member GPSims39's Avatar
    Nov 2008
    Hauppauge, NY
    i did it infront of my house, using the yellow now, took like 2 hours total with the prestone flush two rinses wiht water then the fill, its fun,
  1. Change oil at what %?
    By shawnz90 in forum General Tech Discussion
    Last Post: 07-25-2011, 09:04 AM
  2. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
  3. anyone ever change a gt to a gtp
    By e56505 in forum General Tech Discussion
    Last Post: 02-18-2009, 12:12 AM
  4. How soon do you change the oil after........
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2009, 03:56 PM
  5. s/c oil change
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2008, 05:44 PM
