Thread: LIM change and blocked coolant passage
Results 1 to 5 of 5
  1. #1 LIM change and blocked coolant passage
    Wichita KS
    So my 98 GTP with 140,000 started getting the low coolant light with no external leaks, so started my LIM gasket change. First off i snapped the aluminium snot off the alternator bracket trying to slowly get it out. Then when I pulled the manifold off a coolant passage was full of this nasty gunk. Where it meet the manifold it caused pitting. So I am guessing it was a ball of corrosion? Also snapped a bucnh of brittle vacuum lines in the process as well as a nipple off the boost control so I have to find one of those as well. Fix one thing break another, just my luck. So Parts hunting I go Monday. Here are some pics.
  2. #2 Re: LIM change and blocked coolant passage
    Charles City, IA
    Looks tasty. those elbows always break. Once you get it back together flush the cooling system to get that **** outa there.
    SMGPFC Two Nipple General
  3. #3 Re: LIM change and blocked coolant passage
    SE Level Member The Chad's Avatar
    Harrisburg, PA
    Good thing you caught it when you did! Lifter valley looks fairly clean, much better than mine was.
  4. #4 Re: LIM change and blocked coolant passage
    Take a better pic of your alternator bracket. I probably have one sitting here. You will be very lucky if you didn't snap part of the timing cover as well. That's why GM changed from the 97/98 bracket with metal elbow to 99+ with both elbows as plastic.
    I have the BCA as well if that's the nipple you broke...
    You shouldn't have to worry about that little bit of pitting. It's quite normal.
    Take pics..and I'll shoot you the bracket for shipping costs, BCA.. we can work something reasonable out.
  5. #5 Re: LIM change and blocked coolant passage
    Wichita KS
    I got lucky and no damage to the timing cover. Found a junkyard that gave the the bracket and the BCA for $40. Thanks for the offer. If I goof this up I will have to get with you as I looked all over town for this one.
  1. Coolant Change
    By c002529 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-05-2009, 11:32 AM
  2. benefits of blocked egr?
    By 99prixgt in forum General Tech Discussion
    Last Post: 04-12-2009, 04:03 PM
  3. L26 intake v.s. Blocked off supercharger
    By Andrew_99GTP in forum Turbo
    Last Post: 11-03-2008, 09:05 AM
  4. Benefits of Blocked SC case to L26/L36 UIM .
    By oldsman105 in forum Turbo
    Last Post: 06-17-2008, 03:36 AM
  5. any gains in porting the boost bypass passage?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 10:59 AM
