Thread: 2005 gtp with remote start
Results 1 to 13 of 13
  1. #1 2005 gtp with remote start
    usa
    i have a o5 gtp with a remote start. the issue i am having is that the ac blows when you start it no matter what and i dont know how to get the heat to blow with the remote start. supposidly it has a sensor but it is cold out and still just blowing a/c . the owners manual doesnt say crap about it either. any insight would be appreiciated. the heat does work on the car just not with the remote start. we have tried leaving it on full blast and then remote starting and still nothing.
  2. #2 Re: 2005 gtp with remote start
    MO
    Have you considered that it blows cold because the engine isn't warm yet?
    <brandonl2000> LMAO D!!
  3. #3 Re: 2005 gtp with remote start
    usa
    thats not the problem. tried it several times with the engine at normal operating temperature
  4. #4 Re: 2005 gtp with remote start
    SE Level Member hklvette's Avatar
    Jun 2010
    Christiansburg, VA
    i'll have to try that on my car, but could the cabin temp sensor be bad?
    '05 silver GTP, '98 Cherokee, '78 M880, '70 M35A2
    "Drag racing is for fast cars. Autocross is for fast drivers."
  5. #5 Re: 2005 gtp with remote start
    MO
    Actually, my thought was that it reads the outside temperature and adjusts accordingly.
  6. #6 Re: 2005 gtp with remote start
    Having recently installed a Viper 5901 into my 00 Regal, the basic principles of how this should work is that the remote starter powers up the wiring that gives the climate control and blower motor power. From there the climate control uses it's settings to heat/cool the car as it sees fit. Now with that out of the way... let's ask some further questions.
    Is this your first cool season with the remote starter?
    Who installed it?
    Not being familiar with the 05, I'd suggest checking the schematics to ensure the ambient (exterior) and interior temp sensors are being read by the climate controls when the remote is on. It might be that the circuit that supplies power/ground to the sensors isn't active and it's defaulting on cooling. The minute you put the key in and give the rest of the systems power, the sensors come alive and you get heat.
    Maybe the actuators that control temp aren't being powered.
    There are a lot of possibiliies which is why I ask...who installed it.
  7. #7 Re: 2005 gtp with remote start
    Jun 2010
    Christiansburg, VA
    On my '05 with factory-installed RS, the climate controls are over-ridden when the RS is used. The fan goes to full-speed, and on hot days, the AC turns on. haven't tried it in the cold yet.
  8. #8 Re: 2005 gtp with remote start
    Jun 2010
    Christiansburg, VA
    I tried RS on my car last night with the ambient around 45-50. Blows ice cold, even at full operating temp. After reading the manual, I think I've figured out the problem:
    The RS system uses the outside ambient air temperature sensor to determine whether to heat or cool the car. I think this sensor is not equipped on cars that have the 3-button DIC (like mine), causing the system to default to AC mode. When I get around to calling Morad and updating to a 5-button DIC, I will be able to test this theory.
  9. #9 Re: 2005 gtp with remote start
    New Brunswick
    On other cars like sunfires that have no ambient sensors still disable the a/c when its cold out( they dont have factory remote starts so it must be to protect the compressor or something)...even my old one that I installed a/c using factory parts did the same. I think its something to do with the cycling switch knowing the temp.
    So with this is a possibilty that the climate control will turn on the heat when the pcm data says the a/c is disabled this would eliminate the need for a sensor on 3 button models...with the 5 button dic I would imagine this will override all this and make it more accurate for choosing the temp.
  10. #10 Re: 2005 gtp with remote start
    usa
    it's a factory installed remote start.the owners maual says it puts on the a/c or heat according to outside temps but doesn't mention what those temp are.i would think that at forty degrees outside it should switch to heat but it still blew cold.i was also thinking how the hell it knows what temp it is without a thermometer in the car like some cars.seems like a waste of time to have something wired into the computer reading temps and deciding what to do but not informing the driver of outside temps.
  11. #11 Re: 2005 gtp with remote start
    Jun 2010
    Christiansburg, VA
    racergurl, do you have a 5-button or 3-button DIC?
  12. #12 Re: 2005 gtp with remote start
    Jun 2010
    Christiansburg, VA
    Since its now quite cold out, I learned something about the HVAC during remote-starts:
    If I start my car in the morning near or below freezing, it turns on the front and rear defrosters. After driving the car for a while, if I use remote start again, it turns on the AC. Keep in mind my car has the 3-button DIC. I think what is happening is that the only temperature references the car has are the coolant sensor, and the intake air temp sensor, both of which are skewed by running the car. I'm going to try installing just the ambient air temp sensor on my car and see if that fixes it.
  13. #13 Re: 2005 gtp with remote start
    GT Level Member 05CompG's Avatar
    Arizona
    Im actually having this same issue. It doesnt get that cold here in AZ but on the cooler nights, i dont want to hop into a freezing car...I have a 5 Button DIC and when i use the remote start, sometimes it comes on and sometimes it doesnt. I've noticed that it cant have anything to do with the outside temps because at times, i have had it come on when its freezing out and other times, it didnt activate and it was a lil toasty out. So im lost...
    Her Name...Stacii Dash
  1. Remote Start???
    By nikkigpgt00 in forum Audio, Security & Visual Electronics
    Last Post: 08-03-2010, 11:09 PM
  2. Remote Start
    By RideMr2 in forum General Tech Discussion
    Last Post: 05-15-2010, 11:09 PM
  3. Replies: 3
    Last Post: 01-26-2010, 08:16 PM
  4. 02 GP Remote Start
    By Volvit in forum Audio, Security & Visual Electronics
    Last Post: 11-21-2009, 05:15 PM
