Thread: 0 rpms and tcs light on while car is running?
Results 1 to 18 of 18
  1. #1 0 rpms and tcs light on while car is running?
    SE Level Member quadracer960's Avatar
    indiana
    So i started the gtp today and noticed that the tach said 0 rpms and also noticed that my tcs light was on. Before anybody asks, yes the car was running and i didnt press the button. This happened before but didnt think anything of it. What could be the problem between the two? THANKS btw its a 00 gtp with 94,000 on the ticker with no ses lights on.
  2. #2 Re: 0 rpms and tcs light on while car is running?
    GT Level Member rolyat's Avatar
    OKC
    Crankshaft position sensor, It's behind the harmonic balancer.
    2000 GTP: autolite 104's, 180 t-stat, shift kit, open cone spectre, 1.9 rockers, polished TB, ported blower, SD headers, zzp mps/3.4 pulley, 42.5lbs injectors, Reptile tune
  3. #3 Re: 0 rpms and tcs light on while car is running?
    Yea your CPS is bad.
    i have a extra CPS senosr laying around, you can have it for the price of shipping if you want.
  4. #4 Re: 0 rpms and tcs light on while car is running?
    Akron Ohio
    X3 I had the same thing go bad on my car
  5. #5 Re: 0 rpms and tcs light on while car is running?
    Nov 2009
    Grand haven
    Quote Originally Posted by rolyat View Post
    crankshaft position sensor, it's behind the harmonic balancer.
    this ^^^^
  6. #6 Re: 0 rpms and tcs light on while car is running?
    indiana
    is there any side-effects besides a bad rpm reading and the light? i turned it off and back on and it went back to normal. how hard is it to install. i put one on my silverado, never the gtp lol.
  7. #7 Re: 0 rpms and tcs light on while car is running?
    Dec 2008
    philly
    Mine would drop rpms to zero while driving, sometimes stalling.
    its not hard the PITA part is getting the harmonic balancer bolt off.
    I used a Lisle Harmonic Balancer Puller for GM and it worked perfect.
  8. #8 Re: 0 rpms and tcs light on while car is running?
    indiana
    Ok then. Seems like a common issue. Looks I got something to do over the weekend. Thanks for your help guys!
  9. #9 Re: 0 rpms and tcs light on while car is running?
    SE Level Member Roanokegprix's Avatar
    Roanoke Va
    Quote Originally Posted by quadracer960 View Post
    did you get it put on? what bolts did you use? seems like the 1/4x28x3 is not big (round) enough, could I have a different harmonic balancer?
  10. #10 Re: 0 rpms and tcs light on while car is running?
    Georgia
    It's a common issue. Eventually the car will start stalling on you and then, like mine did, will leave you stranded. It's not that difficult to change but it would help if you had access to a lift like I had. You'll need balancer puller, I just went to Advance and got one, and you'll need the 1/4x28x3 bolts that did not come with the puller. Make sure that you get the bolts aligned correctly, it's kind of tricky, and also the center puller blot where it goes into the crank, I used a socket to keep it from messing up the threads for the balancer bolt. Once the balancer is off you can take it from there. Good luck.
  11. #11 Re: 0 rpms and tcs light on while car is running?
    Charles City, IA
    no, you are not lining the bolt up right, it is kinda hard to find the hole on the first time.
    SMGPFC Two Nipple General
  12. #12 Re: 0 rpms and tcs light on while car is running?
    MO
    that's what she said.
    <brandonl2000> LMAO D!!
  13. #13 Re: 0 rpms and tcs light on while car is running?
    Charles City, IA
    Quote Originally Posted by ZR1Vette09 View Post
    I just load it up with flour and aim it for the wet spot.
  14. #14 Re: 0 rpms and tcs light on while car is running?
    Roanoke Va
  15. #15 Re: 0 rpms and tcs light on while car is running?
    SE Level Member Vlad0691's Avatar
    Dacula, GA
    ^^ x2
    CAI, 180* T-Stat, SD Headers, EGR Delete
    I have hazy headlights <3.
    R.I.P.
  16. #16 Re: 0 rpms and tcs light on while car is running?
    Georgia
    Same thing with my car. Been doing this for a while, now having a problem with it shutting off, sometimes it starts right up other times it takes 10 to 30 minutes. Run a DTC scan, came back with PO336 crank position sensor circuit, range or performance problem. Have the part but need the correct puller. This does answer the tach and tcs problem. Thanks
  17. #17 Re: 0 rpms and tcs light on while car is running?
    SE Level Member tai27yiuop's Avatar
    Mar 2013
    Portland, OR
    Same problem here, stalling, starting issues, engine generally runs rough, etc.. Have yet install new sensor.. will post afterwords.. wish me luck
  18. #18 Re: 0 rpms and tcs light on while car is running?
    Banned
    Jan 2013
    Colorado
    Would this cause the abs light to be on as well?
  1. Daytime running light (DRL) modification help
    By Vinton GP in forum General Tech Discussion
    Last Post: 09-28-2009, 08:09 PM
  2. trac light on; rpms zero no power
    By skeen01 in forum Introductions/Noob Questions
    Last Post: 06-25-2009, 01:43 AM
  3. How to turn off daytime running light on 2008 GP
    By timc in forum General Tech Discussion
    Last Post: 02-06-2009, 01:51 PM
  4. RPMs stuck at 4000 with check engine light
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2008, 12:25 AM
  5. Help Car running rough SES light MAF dead
    By RNUOVR in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2008, 07:25 PM
