Thread: How to turn off daytime running light on 2008 GP
Results 1 to 10 of 10
  1. #1 How to turn off daytime running light on 2008 GP
    Feb 2009
    Miramichi, New Brunswick
    How do you turn off the daytime running lights on a 2008 Grand Prix
  2. #2 Re: How to turn off daytime running light on 2008 GP
    TDCRacing
    Guest
    More than likley pull the DRL fuse. It is also likley a 10 amp red fuse. That's how you do it on 97-03 anyway.
  3. #3 Re: How to turn off daytime running light on 2008 GP
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    Turn the switch on the light control.
  4. #4 Re: How to turn off daytime running light on 2008 GP
    May 2008
    Winnipeg, MB
    you can't, at least thats the conclusion I've come to after posting many a thread and had no sucess with my 07, only option was modifying the pcm
    2007 Pontiac Grand Prix
  5. #5 Re: How to turn off daytime running light on 2008 GP
    TDCRacing
    Guest
    The PCM has nothing to do with the DRL's on these cars.
  6. #6 Re: How to turn off daytime running light on 2008 GP
    May 2008
    Winnipeg, MB
    well then even the sugestion I got from one member about modifying the pcm is junk, turning off the daytime running lights while driving just can't be done as far as I know
  7. #7 Re: How to turn off daytime running light on 2008 GP
    TDCRacing
    Guest
    Has any one tried to pull the DRL fuse to see if it works??
  8. #8 Re: How to turn off daytime running light on 2008 GP
    Donating Users blowfishRus6's Avatar
    g.a.
    dang i like my 04 more and more every day
    i can turn mine off
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  9. #9 Re: How to turn off daytime running light on 2008 GP
    g.a.
    wait never mind. i can turn the head lights off but not the orange lights at the bottom. once you put it in drive they come on. if you run with the foglights on tho it dont look bad
    its slow.
  10. #10 Re: How to turn off daytime running light on 2008 GP
    May 2008
    Winnipeg, MB
    there isn't a fuse for the DRL
  1. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  2. Daytime running lights
    By Girevik in forum General Tech Discussion
    Last Post: 01-05-2009, 12:40 PM
  3. Turn a se into a gt/gtp
    By 99PHILLYGRANDPRIX in forum General Tech Discussion
    Last Post: 10-26-2008, 03:58 PM
  4. Help Car running rough SES light MAF dead
    By RNUOVR in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2008, 07:25 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
