Thread: trac light on; rpms zero no power
Results 1 to 15 of 15
  1. #1 trac light on; rpms zero no power
    richmond hill, ga
    Hello, i hope someone can help that has experienced this or is still in the throes of this aggravating problem. i have a pontiac grand prix 2000, up until know i have had a wonderful love affair with my car, outside of regular maintenance no problems. recently my car has acted sluggish it acts like it wants to stall the trac off light comes on and then the rpms go to zero in perfect weather conditions. the car will continue to run on occasion then other time i lose all power and the car dies, needless to say this is not good in traffic and praying i dont get rear ended. i have started driving in the right lane more often than not so that i can pull over if necessary. its scarry when the power goes. i have searched the internet and several web site offer different things. more often the owners have spent several thousands trying to pinpoint the issue. if anyone has the pr oper diagnosis i would appreciate a response thank you for your time
  2. #2 Re: trac light on; rpms zero no power
    Becca Boo MizzBecca's Avatar
    Michigan
    I actually experienced this problem. Have you hooked up any subs or anything like that recently?
    I drive a POS
  3. #3 Re: trac light on; rpms zero no power
    SE Level Member trenaro's Avatar
    Feb 2009
    KC
    Sounds like the symptons of a bad Crank Position Sensor.
  4. #4 Re: trac light on; rpms zero no power
    richmond hill, ga
    thank you for taking the time to respond do i need to wait till this happens again to have the computer read any guesses on the cost of repair
  5. #5 Re: trac light on; rpms zero no power
    SE Level Member dibs's Avatar
    Topeka, KS
    I am new to this site, and have found really helpful posts on here. I am having this same problem. The only difference is that the Service Engine Soon light just came on. I have litterally never seen it on until tonight. About a month ago I lost the RPM gauge, but that was all. The next day, it was working, so I thought nothing of it. Then, just a few hours ago the RPM gauge went dead, the Trac Off light came on, and then 30 seconds later, the SES light came on. I still owe a grand on this grand prix so I am hoping that I can fix it. I don't have much money, so taking it to a shop isn't really an option. It is a 99 Grand Prix GT. On top of this, I have also had the infamous hard shifting problem, but it comes and goes and has done it since I got it. I am not to worried about that problem right now, but this new one concerns me. Any suggestions or thoughts would be great.
    Thanks in advance,
    DIBS
  6. #6 Re: trac light on; rpms zero no power
    Topeka, KS
    New Info : I just got back from taking it out for a spin to see if anything had happened, and the RPM works and the Trac Off is off, but the SES light is still on. Honestly, it runs fine, doesn't feel weird or sound weird.
  7. #7 Re: trac light on; rpms zero no power
    St. Louis Mo.
    I would goto Autozone to have them check what SES codes you are throwing. It is hard to truly diagnosis your problem without knowing what codes you are throwing. They will do it for free.
    James Shafer
    St. Louis MO
  8. #8 Re: trac light on; rpms zero no power
    SE Level Member Chernobyl's Avatar
    Chicago
    Quote Originally Posted by dibs View Post
    Thanks in advance,
    DIBS
    I have this as well. At one point when I was going for a drive, the Tach died and the trac light went on about 3 times in a 10 minute span. Each time it would die, I would pull over and restart the car, which would fix it, for a short time. The 3rd and final time, the SES light went on, so I took it to Autozone. They reported that it was the Crankshaft Position Sensor, and lo and behold, as soon as I leave, the light goes off.
    So, it's an intermittent problem, but a problem nonetheless. It is not terribly difficult to replace yourself, and there is an excellent walkthrough at http://www.grandprixforums.net/cps.php
    It will cost you probably 75 dollars, including the puller tool, sensor, and loctite, assuming you possess tools.
  9. #9 Re: trac light on; rpms zero no power
    Banned - Busted For Scamming
    Feb 2009
    puller, lol you can use two crowbars or you can just buy the bolts for the normal harmonic balancer puller.
  10. #10 Re: trac light on; rpms zero no power
    Topeka, KS
    Thanks a lot guys, I will take it there today.
  11. #11 Re: trac light on; rpms zero no power
    Topeka, KS
    Well, ofcourse when I got to Autozone the light was off, but the part is only 26 bucks so that is good to know. Hopefully I will get around to doing it this weekend and I will let you know what happens. Thanks again for your help.
  12. #12 Re: trac light on; rpms zero no power
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    The tac gets its signal from the CPS, so when the tac drops to 0, yet the car is still running, it's a pretty good indication that the CPS is on its last leg. Though I would have sprung the extra money for a GM part. Swapping it is not super hard, but it's not something you want to have to do again 4 months down the road when the cheap-o Auto Zone part fails.
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  13. #13 Re: trac light on; rpms zero no power
    Topeka, KS
    Thanks for explaining it, and honestly if I had the money I would go for a better part, but I just dont right now. What I was wondering is when I looked at that walkthrough, it seemed like they were doing more than just changing the CPS. From what I can tell, the CPS is on top and easy to get to, but he was under the car from the tire well, which makes me ask the question if he is explaining how to do something else or if this is necessary to change the CPS. If someone could explain this to me, that would be great.
  14. #14 Re: trac light on; rpms zero no power
    I live here. UR LOSN's Avatar
    Rockford, IL
    Welcome to the forums!!
  15. #15 Re: trac light on; rpms zero no power
    Chicago
    The money difference is negligible. It's not terribly difficult to do, but you don't want to keep crawling under there. Spend the extra 5 dollars to never have to do it again.
    In addition, you don't seem to understand what the CPS is. The Crankshaft Position Sensor is embedded in the crankshaft area, which does require getting under the car through the tire well.
  1. Tac quits and goes to zero/trac off light comes on
    By holorinhal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-01-2012, 05:37 PM
  2. Trac off light on, No Tach
    By 98greengt in forum General Tech Discussion
    Last Post: 07-27-2009, 11:22 PM
  3. my low trac is lit and so is the abs light
    By beast55 in forum General Tech Discussion
    Last Post: 06-27-2009, 01:23 PM
  4. RPMs stuck at 4000 with check engine light
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2008, 12:25 AM
  5. abs and trac off light staying on
    By gtpinsc in forum General Tech Discussion
    Last Post: 08-20-2008, 07:34 AM
