Thread: Coolant Swap
Results 1 to 20 of 35
  1. #1 Re: Coolant Swap
    USA
    Alright well thank you for your opinion. Does anyone else think switching would be a bad idea? What is the best way to completly flush the cooling system?
  2. #2 Re: Coolant Swap
    I still say stick with green, but heres what you should do.
    drain rad, by pulling lower rad hose off
    then pull the front knock sensor, let the coolant drain out of the hole and put it back inand the rad hose back on.
    fill with water till full, then run the car untill the themostat opens and add more water, then let it run a min or two longer and shut it off.
    then pull the lower rad hose again and drain, then pull the knock sensor again.
    do it one more time if need be to get the extra coolant out.
    Now have everything hooked back up and fill the rad with coolant. then open the bleeder valve on top of the thermostat houseing. turn the car on and let it run till the themo opens and add more coolant untill full, then wait a little bit while it go's into the motor and starts to carry out the air. You will see bubbles out of the bleeder valve .
    wait for the bubbles to stop and then it should be straight coolant coming out. Close the bleeder and put the rad cap back on and your done.
    wait a few days and check the level and the mix to see if if is right, depending on where you live will determine if it needs to be stronger or not, for winters and such.
  3. #3 Re: Coolant Swap
    USA
    Thank you! How important is taking the sensor off? Won't that be flushed when the water is run through the system?
  4. #4 Re: Coolant Swap
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    pulling the sensor will help to drain your block. Radiator holds about a gallon and the whole system is +12 qts., so you're only getting 1/3 of the coolant out by draining the radiator.
  1. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  2. Gen V swap.. coolant everywhere.
    By Brooks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 04:31 PM
  3. coolant ?
    By 04GTP in forum Off Topic Discussion
    Last Post: 06-24-2008, 09:42 AM
  4. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  5. 99+ coolant reserve swap??
    By hotshot in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 11:11 AM
