Thread: Dropping tranny pan
Results 1 to 8 of 8
  1. #1 Dropping tranny pan
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    So i'm going to drop my trans pan tomorrow, change the filter and fill it back up. Is it good to fill it with dex VI even though the converter will still be full of dexIII? And how much fluid should i buy? i was thinking 8 quarts should do it
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  2. #2 Re: Dropping tranny pan
    get the newest dexron and yes 8 should do it, are you getting that kit (filter and gasket), i think the rubber gaskets are better which is the one in a kit a bought
  3. #3 Re: Dropping tranny pan
    Dec 2008
    London, Ontario
    yeah ill be getting the kit which should have a rubber gasket, and yes they are better ive had cork ones leak on me
  4. #4 Re: Dropping tranny pan
    ok sounds good, maybe put a shift kit in while your at it to help the tranny.
  5. #5 Re: Dropping tranny pan
    Dec 2008
    London, Ontario
    good idea. Ill order one tomorrow
  6. #6 Re: Dropping tranny pan
    If the gasket you take off is rubber with metal inside, that's the factory (expected lifetime) gasket and you should resuse it. Read the instructions that come with the service kit about filter neck being snug and not replacing the collar if it's snug.
    The factory gasket is a pricey gasket and it's the best you can get. Those rubber ones work, but they don't work like a factory gasket.
  7. #7 Re: Dropping tranny pan
    just dont get a ZZP shift kit. go intense
  8. #8 Re: Dropping tranny pan
    Dec 2008
    London, Ontario
    Ok thanks i will get the oem gasket, and if the one on there is still good i will return the one i bought.
    Quote Originally Posted by Fivefingerdeathpunch
    Yeah man i knew zzp's kit was s***, intense is what i already ordered lol
  1. Best gains for dropping $2000 into a GTP
    By MidnightSpecial in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2010, 11:01 AM
  2. Dropping some Serious cash
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2010, 11:08 PM
  3. Dropping cradle
    By Pontiac99GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2009, 11:38 AM
  4. Help with dropping the cradle
    By nlinesk8s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-17-2008, 06:47 AM
  5. Tips on dropping in a motor ?
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2008, 04:52 PM
