Thread: 99+ coolant reserve swap??
Results 1 to 3 of 3
  1. #1 99+ coolant reserve swap??
    SE Level Member hotshot's Avatar
    R.I.
    I swapped the coolant reserve bottle on my 98 GTP today and I know it seems streightforward but theres no way to bolt it onto the car on the bottom. Theres a lil hole there but its not threaded and it doesn't go all the way to the other side where I could get a new nut/bolt combo to hold the bottom down. I am not driving the car yet so for now I zip tied it in place to hold the bottom from moving but I want something more secure. I had to drill new holes for the top two screws since they didnt match up but theres not enough room in the engine bay to get a drill and self tapping screw in there.
    Anyone swap the coolant bottle in there 97/98 gp and run into this?? Any suggestions would be freatly appreciated.
    98 GTP - slp powerflo cat back, built tranny, AP104s, homemade FWI and intense 180 stat.
  2. #2 Re: 99+ coolant reserve swap??
    R.I.
    In case someone runs into the same situation theres a special fastener for this. I had to look at a ton of websites before stumbling on it on the intense racing site.It is a GM part so it will be easier to go get it at the dealer. If I knew this would have been such a P.I.T.A. I would have took pics and made a how to for the 97-98 gtp guys since it SEEMS like a streight forward thing.
  3. #3 Re: 99+ coolant reserve swap??
    Huntington, WV
    I just used a bolt with washers to fasten it at the bottom. I almost did a write up myself. I found directions on this on thrashers website. It was showing how to install their CAI and also showed how to change the bottle.
    1995 Trans AM 72k miles, 6 speed and all stock.
  1. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  2. Coolant leak
    By jdgaetan in forum General Tech Discussion
    Last Post: 05-31-2008, 03:24 AM
  3. leaking coolant
    By rdicarlo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2008, 10:04 AM
  4. Coolant leaks
    By golden_c_ninja in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2008, 10:13 PM
  5. How much coolant?
    By chitownchevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:30 AM
