98 Regal GS, Did the Gen III to a V, swapped LIM/Blower/TB.
Engine started, ran for a bit, then died.
I did not take it for a spin, just sat it at idol when this happened.
No crazy noises or horrifying smoke or anything.
The engine just turns and turns but wont fire.
-I checked the fuel that was fine. pumps running and fuel rails/injectors look good.
-I checked the plugwires/coils/ICM all tested ok on resistance/ground.
+I removed the new blower and found coolant in places it shouldn't be. The LIM is coming off next.
Besides soaking all the coolant up from the LIM/Blower, changing the oil and properly sealing the TB adaptor gasket what else do I need to do to make sure all the coolant is out of the system.
