Thread: Can u make your supercharger louder without an intake?
Page 5 of 7 FirstFirst ... 34567 LastLast
Results 81 to 100 of 121
  1. #81 Re: Can u make your supercharger louder without an intake?
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    I just bought a ported case and it has the two slits on the side epoxied shut, this is supposed to make the sc whine louder as well right? also howtough is it to change the needle bearings?
  2. #82 Re: Can u make your supercharger louder without an intake?
    Jul 2008
    sumter,south carolina
    machine shop for needle bearings.
    02 GTP with mods 05 GP for DD
  3. #83 Re: Can u make your supercharger louder without an intake?
    GT Level Member 40th GP's Avatar
    Utah
    It was $10-12 each for me too, but I still don't understand...everyone seems to have an opinion on what oil and/or coupler to buy, but nobody seems to have any reason why. What makes the GM oil better than zzp oil? What makes the zzp coupler better than the ebay coupler? If money was no object I would just go with whatever everyone said, but I don't have a ton of cash laying around. I am looking for info on what makes one better than another, or why I should go with one over the other. If the zzp coupler is no better than the ebay coupler, why spend more to get that one? I would rather put the extra money into one of the many other things the car needs.
  4. #84 Re: Can u make your supercharger louder without an intake?
    I bought the ebay coupler andit works fine and comes with allthe oil you need for around 35 shipped. The coupler is the same as the ZZP, it is made of the same material and is the same in every way!
  5. #85 Re: Can u make your supercharger louder without an intake?
    Quote Originally Posted by 40th GP View Post
    ZZP is not fleabay.
    You might very well NEED 8 fl oz.... not 6 like ZZP says. I just replaced my fluid yesterday.... took JUST under 8 fl oz and it wasn't bone dry, just held it upside down till i grew impatient.
    With fleabay, you have NO idea what fluid you're getting.
    Fleabay headers might be great but even those aren't that great... you need to make your own DP, replace the flex and trim the crossover. Easily another $100+ to add to your costs.
    So why again am I recommending parts that I know work? Because I value my car.
  6. #86 Re: Can u make your supercharger louder without an intake?
    Jul 2008
    may as well take this a lil more off topic... but i didnt have to do any of that to my ebay headers.
  7. #87 Re: Can u make your supercharger louder without an intake?
    but you stilll have the leaky flex and the goose neck.
  8. #88 Re: Can u make your supercharger louder without an intake?
    To the guy with the slits filled shut...I hope you like chunks of metal in your engine.
  9. #89 Re: Can u make your supercharger louder without an intake?
    I was asking a question have you personally blown an engine or know somone who has ? Information with smart... Statements like that would be helpful.
  10. #90 Re: Can u make your supercharger louder without an intake?
    A few. The pieces get pushed out and into the motor. A couple intercooled guys have had the luxury of an IC under the blower and there are pics somewhere on here where the metal is sitting on the core.
  11. #91 Re: Can u make your supercharger louder without an intake?
    That's good info this case came from glanzergtx and he was running it on his car. - have been running epoxied heads and intake for quite a while with no problems but I will prob remove the epoxy from these if there are reported cases of this happening. Thanks for the info man!
  12. #92 Re: Can u make your supercharger louder without an intake?
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    how do you get the needle bearings out, is there a little trick to it
  13. #93 Re: Can u make your supercharger louder without an intake?
    Quote Originally Posted by fremmy182 View Post
    I asked the same question and the answer I got was take it to a machine shoP and that's prob what I'm gonna do
  14. #94 Re: Can u make your supercharger louder without an intake?
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    my s/c case was ported by reptile and the slits r filled with aluminum epoxy and they have been running that way for 20k+ miles and i have not had any problems at all. what it does is it makes u hear whien when your onyl about 1/2 throttle instead of only hearing it when you WOT. but at WOT it screams id say just leave it
  15. #95 Re: Can u make your supercharger louder without an intake?
    Charles City, IA
    Just FYI I filled the slits on bryants case, reptile does not do that.
    SMGPFC Two Nipple General
  16. #96 Re: Can u make your supercharger louder without an intake?
    Waterloo, Iowa
    lol thats what i meant haha since i got the case from nick
  17. #97 Re: Can u make your supercharger louder without an intake?
    You thread the hole on the bottom side of the case and install a grease fitting then press them out with grease.
    New ones can be pressed in.
  18. #98 Re: Can u make your supercharger louder without an intake?
    i still dont really understand, because i got metal shavings inside them. Unless i can get a q tip and just clean them out really good
  19. #99 Re: Can u make your supercharger louder without an intake?
    if you look at the outlet side of your blower you'll see two holes just above the H bridge.
  20. #100 Re: Can u make your supercharger louder without an intake?
    Jul 2008
    i have 0 leaks... the downpipe occasionally scrapes on ****... usually when im going a high rate of speed and hit a dip in the road making the suspension squat down pretty far... but its done this so many times in the past the bottom of that gooseneck is dented in and is now flat lol.
  1. Make A 4" Fenderwell Intake (FWI)[*]
    By Street Wolf in forum How To Write-Ups/Tech Tips
    Last Post: 05-17-2019, 05:23 PM
  2. make my own intake question
    By xsvtank in forum General Tech Discussion
    Last Post: 06-15-2010, 03:35 AM
  3. HOW TO: Make a heat shield for your intake
    By daveydavido in forum How To Write-Ups/Tech Tips
    Last Post: 04-05-2010, 12:07 AM
