Thread: Stuck in park! Cant push shifter button!
Results 1 to 17 of 17
  1. #1 Stuck in park! Cant push shifter button!
    SE Level Member 01STOCKGTP's Avatar
    Nov 2010
    Michigan
    So the other day drove my car to a restaurant and when we came out to leave i couldn't get it out of park... the shifter button on the knob wouldn't push in. Since i had heard about this problem before with gps i just used the shift lock release button the next couple times i had to drive it. My key hasnt gotten stuck like i have seen on here as an associated problem.
    Checked my BTSI fuse......Checked to make sure i had brake lights....both were fine.
    So i did what any broke ass college kid would do and took the center counsole apart and rubber banded the shift lock release lever all the way open so i don't have to push the button every time.
    The only problem is now my shifter could potentially be bumped into reverse or park going highway speed because i basically took away that safety feature!
    Any ideas what could be wrong and how to fix it for real with something other than a rubber band?
  2. #2 Re: Stuck in park! Cant push shifter button!
    Did you check at the soleniod for power! How about listening for a clicking from it!
    Nab a picture of it! I've seen on my own car where teh white piece that would be pushed from above to release it can jamb up!
  3. #3 Re: Stuck in park! Cant push shifter button!
    Nov 2010
    Michigan
    Havent checked for a clicking. I do know that the while plastic piece doesn't move when i push down the brake. It moves easily with the shift lock release which i have rubber banded engaged
  4. #4 Re: Stuck in park! Cant push shifter button!
    Delaware, OH
    You still have to squeeze the release to shift it into Reverse or park. At least that's how mine is and I've had it rigged for 2 years now.
    So as long as you can control the urge to throw it into reverse or park u should be good
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  5. #5 Re: Stuck in park! Cant push shifter button!
    ill have to look into this myself, i've been doing the slap chop on my shifter to pop the release down, the white button dont do dick to release mine, and ive had the console out 4 times since august and its been cold and i dont want to deal with it.
    thank god the ignition release worked, friggin dead battery cough me off guard.
  6. #6 Re: Stuck in park! Cant push shifter button!
    Nov 2010
    Michigan
    im pretty sure i don't need to push the button and can just push it forward when driving. I put the parking brake on while in drive and could just push it on forward into reverse then park with no button....
    scary!
  7. #7 Re: Stuck in park! Cant push shifter button!
    man im glad mine has reverse lock out, you need to push the button in to get it into reverse or park.
    regals rule...just kidding
  8. #8 Re: Stuck in park! Cant push shifter button!
    Nov 2010
    Michigan
    do you mean the actual shifter knob button or the shift lock release button?
    because im prty sure we all understand that mine is held open as is yours correct?
  9. #9 Re: Stuck in park! Cant push shifter button!
    Quote Originally Posted by 01STOCKGTP View Post
    my release button, that you would use to bypass the shifter button if the button failed dont do nothing, i have to slam my hand on the shifter knob to get out of park.
    but once its in drive i have to push the shifter button to get to reverse or park.
    its only frozen when in park, after i slam it and go into gear it works.
    are you saying that you have the shifter button rigged to stay down all the time? now that would be scary i must say.
  10. #10 Re: Stuck in park! Cant push shifter button!
    Nov 2010
    Michigan
    Ya it was real simple to do. I took out the center counsol and simply looked what the shift lock release button was doing. it pulls out the white plastic disc on the cable allowing you to push the knob button and shift like nothing was wrong.
    It is kinda scary. Car off, Keys out, I can put it in any gear even without using the brake.
    This is the whole reason i posted this to see if im a complete idiot for disabling this safety feature... no doubt it isn't strickly legal
  11. #11 Re: Stuck in park! Cant push shifter button!
    ok then lol im going to pull mine apart and try to fix it the right way, i may have a wire pulled off or something easy, i've had the console off so many time i may have pulled something out of place and it worked it way off over time or something, thanks.
  12. #12 Re: Stuck in park! Cant push shifter button!
    Regals do rule!
    I pulled the white piece off ...or well..it fell off. Meanwhile my shifter works totally normal w/o it.
  13. #13 Re: Stuck in park! Cant push shifter button!
    thanks bill. its getting warm out, ill have to dig into it and have a look.
  14. #14 Re: Stuck in park! Cant push shifter button!
    C'mon man..it's at least 50 out... rainy and sucky..but all you gotta do is smile at the neighbors when you get outta the foggy window car. They'll wonder what you were doing in there.
    My neighbors don't even bat an eye at that stuff anymore. They just accept whatever they see as "normal" for me.
  15. #15 Re: Stuck in park! Cant push shifter button!
    im living in an apt building, they dont let anyone work on there cars in this lot, i was waxing my car and was told to do it else where.
    since im here ive done a full tune up, full brake job , disks and all at stop and shops lot, replaced a heater core in the park, new power ports in pep boys lot, removed my struts at a friends house who lives around the corner from a front end shop to get new mounts put on, and so on lol its been a real trip living here, I MISS MY GARAGE DAMN IT!!!!!!!!
    and now ill be doing side view mirror replacement due to some ass busting it for me!!!!
  16. #16 Re: Stuck in park! Cant push shifter button!
    I'm a quick spin up the road from you. Stop on over if you wanna borrow one of the garage bays.
    Close is relevant... I have friends that come from Ohio ....lol
  17. #17 Re: Stuck in park! Cant push shifter button!
    thanks bill, jersey is closer than ohio lol , im trying to get a house in tuexedo ny tax problems keep f ing me and my girl over still, but its got a 4 car garage, 2 cars deep and 2 1/2 cars wide, its a heaven i'll just have to wait for.
  1. Push button for park-lock solenoid in column??
    By BLOWN93LX in forum General Tech Discussion
    Last Post: 04-05-2011, 12:10 PM
  2. Car won't move out of park and key stuck in ignition
    By DanGTP in forum General Tech Discussion
    Last Post: 10-09-2010, 03:46 PM
  3. Stuck in park
    By Ricky21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2010, 10:37 AM
  4. Push button Start
    By crock in forum General Tech Discussion
    Last Post: 08-31-2010, 04:41 PM
  5. Shifter button stuck?? Cant remove key
    By PRIXSY in forum General Tech Discussion
    Last Post: 02-25-2009, 07:45 PM
