Thread: Stuck in park! Cant push shifter button!
Results 1 to 17 of 17
  1. #1 Re: Stuck in park! Cant push shifter button!
    SE Level Member 01STOCKGTP's Avatar
    Nov 2010
    Michigan
    man im glad mine has reverse lock out, you need to push the button in to get it into reverse or park.
    regals rule...just kidding
    do you mean the actual shifter knob button or the shift lock release button?
    because im prty sure we all understand that mine is held open as is yours correct?
  2. #2 Re: Stuck in park! Cant push shifter button!
    Quote Originally Posted by 01STOCKGTP View Post
    my release button, that you would use to bypass the shifter button if the button failed dont do nothing, i have to slam my hand on the shifter knob to get out of park.
    but once its in drive i have to push the shifter button to get to reverse or park.
    its only frozen when in park, after i slam it and go into gear it works.
    are you saying that you have the shifter button rigged to stay down all the time? now that would be scary i must say.
  3. #3 Re: Stuck in park! Cant push shifter button!
    Nov 2010
    Michigan
    Ya it was real simple to do. I took out the center counsol and simply looked what the shift lock release button was doing. it pulls out the white plastic disc on the cable allowing you to push the knob button and shift like nothing was wrong.
    It is kinda scary. Car off, Keys out, I can put it in any gear even without using the brake.
    This is the whole reason i posted this to see if im a complete idiot for disabling this safety feature... no doubt it isn't strickly legal
  4. #4 Re: Stuck in park! Cant push shifter button!
    ok then lol im going to pull mine apart and try to fix it the right way, i may have a wire pulled off or something easy, i've had the console off so many time i may have pulled something out of place and it worked it way off over time or something, thanks.
  5. #5 Re: Stuck in park! Cant push shifter button!
    Regals do rule!
    I pulled the white piece off ...or well..it fell off. Meanwhile my shifter works totally normal w/o it.
  6. #6 Re: Stuck in park! Cant push shifter button!
    thanks bill. its getting warm out, ill have to dig into it and have a look.
  7. #7 Re: Stuck in park! Cant push shifter button!
    C'mon man..it's at least 50 out... rainy and sucky..but all you gotta do is smile at the neighbors when you get outta the foggy window car. They'll wonder what you were doing in there.
    My neighbors don't even bat an eye at that stuff anymore. They just accept whatever they see as "normal" for me.
  1. Push button for park-lock solenoid in column??
    By BLOWN93LX in forum General Tech Discussion
    Last Post: 04-05-2011, 12:10 PM
  2. Car won't move out of park and key stuck in ignition
    By DanGTP in forum General Tech Discussion
    Last Post: 10-09-2010, 03:46 PM
  3. Stuck in park
    By Ricky21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2010, 10:37 AM
  4. Push button Start
    By crock in forum General Tech Discussion
    Last Post: 08-31-2010, 04:41 PM
  5. Shifter button stuck?? Cant remove key
    By PRIXSY in forum General Tech Discussion
    Last Post: 02-25-2009, 07:45 PM
