Hi
A couple of you haven't deleted the custom PID list and re-added from the stock list, which will mean that KR wont work for you as you are using the old data (which has changed) in the new versions predefined lists.
You must clear all the extended PIDs first, and delete the display in the realtime dashboard, and then restart Torque (just so we know everything has started fresh, new connection, using the new PIDs) and re-add the KR display
It should then start working!! (at least I hope it does, I don't unfortunately have direct access to a GP to test with)
On the ROM side of thing, 'whatshisface' (me ) would have said that based on the debug - some of the ROMs use old bluetooth drivers, which are known to be broken and there are some *really* broken bluetooth drivers kicking around out there, however some manufacturers don't update their phones so the ROMs are the only way to get newer drivers. Unfortunately the ROM you were using at the time was (or appeared in the debug) using flawed bluetooth driver.
