Hello
1.4.59 is out with initial support for the KR. You will need to *delete* your existing custom PIDs, and re-add them from the predefined list, then restart Torque
After that, you will need to delete and recreate the relevant KR display on your dashboard to make sure you have the fresh KR pid settings
It may work, there's also a good chance it'll be blank - if that is the case I will need a comms debug log to be sent my way (with 'kr' in the description so I know what it's about) and I'll get on with fixing!
Thanks
Ian
EDIT: Thanks for the KR debug. 1.4.60 is now out and should display something after you have performed the above steps!
