Thread: rattling rear end of 97 GT
Results 1 to 20 of 26
  1. #1 rattling rear end of 97 GT
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Lately, some horrible sounds have been coming from my car when I drive down an uneven road surface such as a bumpy or gravel road. The sound comes from the back end. It feels as if the car is absorbing all of the impact and that the suspension is doing very little. It doesn't happen on every bump. The lip of my driveway is about an inch above the road surface. when i drive over that, I don't hear anything abnormal. I do hear the noises as I drive down my driveway when going over the borders of the sections of concrete (there is some type of wood between them). Doesn't have any impact on handling, but I was wondering what could be causing it.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  2. #2 Re: rattling rear end of 97 GT
    Willoughby, Ohio
    the strut tower mounts may be bad, along with the struts themselves
  3. #3 Re: rattling rear end of 97 GT
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    more then likely ur strut mounts, or stab links, but im goin with you have bad stut mounts
  4. #4 Re: rattling rear end of 97 GT
  5. #5 Re: rattling rear end of 97 GT
    rochester,in
    sounds like the strut mounts, if it were me i would replace the struts too while its apart.
  6. #6 Re: rattling rear end of 97 GT
    Newnan, GA
    sounds like everyone is in agreement. So, at most how much should the repair cost?
  7. #7 Re: rattling rear end of 97 GT
    Charles City, IA
    Get some quick struts.
    SMGPFC Two Nipple General
  8. #8 Re: rattling rear end of 97 GT
    Feb 2010
    ohio
    expensive, but the easiest fix if yout not mechanically inclined and its all new parts
  9. #9 Re: rattling rear end of 97 GT
    Newnan, GA
    Put all new quick struts on all 4 and no difference. Any other ideas?
  10. #10 Re: rattling rear end of 97 GT
    sux that the struts didn't fix the noise.
    broken sway bar? end links? theres only so much that moves back there.
  11. #11 Re: rattling rear end of 97 GT
    Newnan, GA
    well, the struts were 14 years old and needed to be replaced anyways.
    The mechanic who tested my last service said his guess was tie rods going in the front. That make any sense on how the noise happens when the front end is on smooth surface?(back is on rough)
    or do I need to add tie rods to the list in addition to this noise?
  12. #12 Re: rattling rear end of 97 GT
    testing tie rods is simple, jack up the wheel and just grab the tire at the 9 and 3 o'clock positions and push to the left and to the right, if theres any play its shot.
    and come to think of it mine were so shot the mechanic i took my car to before i bought it said id fix this first, i never saw tie rods so loose, the wheel moved like 2 inches each way, and they do and will come apart.
  13. #13 Re: rattling rear end of 97 GT
    Newnan, GA
    Going to test them right now
  14. #14 Re: rattling rear end of 97 GT
    Newnan, GA
    Car is on spare tire jacks. I couldn't get either tire to budge right or left. As soon as the camera is done charging I am going to take some pictures for the diagnosis.
  15. #15 Re: rattling rear end of 97 GT
    while its in the air push and pull the bottom of the tire to check for play as well, if so the ball joints are shot. and look closely at the lower control arms bushings,(where they bolt to the car) if they are all torn up then you need new lca's they clunk around pretty too when shot.
  16. #16 Re: rattling rear end of 97 GT
    Newnan, GA
    Here are some:
    Suspension pictures by ejouie - Photobucket
    I can easily take more/better ones just let me know what to focus on
    And I can't get the tires to budge in any direction
  17. #17 Re: rattling rear end of 97 GT
    Newnan, GA
    And then I can move to the rear tires
  18. #18 Re: rattling rear end of 97 GT
    i cant see any of the lca bushings in you pics, but every thing else looks ok.
  19. #19 Re: rattling rear end of 97 GT
    Newnan, GA
    album updated
  20. #20 Re: rattling rear end of 97 GT
    Newnan, GA
    Maybe it's my power steering pump really going out and causing the front vibrations while turning. Things been on its death bed for years, so maybe its finally moving on. As for the rear, I will jack it up tomorrow and take more pictures.
    thanks for the help.
  1. supercharger rattling at low rpm
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2010, 05:15 AM
  2. Rattling Supercharger
    By tboy160 in forum General Tech Discussion
    Last Post: 03-30-2010, 02:36 AM
  3. rattling ass
    By 04muscle in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2009, 11:44 PM
  4. car rattling
    By jack08 in forum Audio, Security & Visual Electronics
    Last Post: 09-20-2009, 04:32 AM
  5. rattling in right rear?
    By runn141 in forum Brakes/Suspension/Chassis
    Last Post: 06-04-2009, 05:00 PM
