Thread: vacuum lines
Results 1 to 8 of 8
  1. #1 vacuum lines
    Hobart
    Is there somewhere that I can get the stock connectors for the vacuum system and just replace them all? Or a kit maybe? Seems I can't find the right size at autozone/advanced Really starting to irritate me, mainly the connector from the throttle body to the hard line that connects to the evap cnstr purge valve
  2. #2 Re: vacuum lines
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    i had to get that part from the stealership
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  3. #3 Re: vacuum lines
    Hobart
    alright thanks, ill try that tomorrow
  4. #4 Re: vacuum lines
    Hobart
    dealer didn't even know what i was talking about, really? i had to rig something up from advance auto parts, car started to idle back to normal for about 10 min, then back to rough idle again
  5. #5 Re: vacuum lines
    dealers are stupid, 99% of the time, its best to know the part number, because the fvck hole on the computer does not know how to use what is in front of him.
  6. #6 Re: vacuum lines
    slc Utah
    I think i may know the part that you are looking for. If it is the T I have a part # for you also. Google it and see if it is what you need. If it is then you have a part #. If its not atleast it tried.
    The part # is 12580695 and it is only about $21 at the dealer.
    Good luck
  7. #7 Re: vacuum lines
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    i just went to checkers and got all my vacuum lines replaced had to do a little modifiying but its alot better
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  8. #8 Re: vacuum lines
    GT Level Member Deviq's Avatar
    SE WI
    I just bought the exact same hose a couple days ago. Had to have the dealer look it up on the exploded view of the car. I'll get you the part number tomorrow when I find the receipt.
    Quote Originally Posted by zildjian102
    .. friggin trashy people. I did stuff with their daughter
  1. Vacuum lines
    By rtorres422 in forum Shops and Community Heroes
    Last Post: 05-24-2010, 10:18 PM
  2. vacuum lines
    By shawn3091 in forum General Tech Discussion
    Last Post: 01-11-2010, 10:15 AM
  3. Different Vacuum Lines...
    By Iron Indian in forum General Tech Discussion
    Last Post: 08-17-2009, 12:47 AM
  4. Identify vacuum lines etc...
    By nmgadb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2008, 12:52 PM
