Thread: Rattling Supercharger
Results 1 to 14 of 14
  1. #1 Rattling Supercharger
    Flint, MI
    My supercharger rattles but only when its under boost, even just a little boost. I have heard everyone say "coupler" when it rattles at idle, havent heard anything about under boost. Also, doesnt seem as if it makes much power while under boost. Two spark plugs have come out smashed in 6 months. I think possibly the Catalytic converter is partially pluggeg and causing all this? Any help or advice would be greatly appreciated.
    -2003 GTP, all bone stock, EVERYTHING
    -Original motor was blown up, people didnt change oil. They also ran 87 octane.
    -Used motor claims 90k, from junkyard, swapped superchargers because coupler was real bad on other one.
  2. #2 Re: Rattling Supercharger
    smashed plugs means something was flying around in the cylinder to do that. they dont just bend on their own. a clogged cat would cause enough restriction to see retarded heat levels and chip a piston.
  3. #3 Re: Rattling Supercharger
    Right...smashed plugs = chipped pistons...gonna need a shortblock. For the coupler, buy one from ZZPerformance, they last forevah. Also, get a 3" Catted Downpipe from them...it gets rid of the stock (possibly clogged one) cat, then it also gets rid of the U-Bend...the most restrictive part of the factory exhaust. That way when you next engine goes in it...you'll be able to let the car breathe and plus you'll be getting better MPG's and performance.
  4. #4 Re: Rattling Supercharger
    Flint, MI
    Thank you both for your replies.
    My problem is, I dont want to spend money/time on a new shortblock if I dont know what killed this one. If it is the Cat, then I would like to know that conclusively. Dont want this present issue to kill future motor.
    With the entire car being stock it seems like the options would be limited as to what could cause the pistons to be "chipping"
  5. #5 Re: Rattling Supercharger
    Clogged cat makes sense. Either that your engine knocked from the start and the 3" downpipe will help you with that.
  6. #6 Re: Rattling Supercharger
    knocking doesnt usually chip pistons do tell you the truth, heat does. when the top ring gap closes because the cylinders are too hot then it pops off a piece of the piston, always in the same spot on every motor.
  7. #7 Re: Rattling Supercharger
    But when knocking is occuring, you have higher cylinder temps which results in post above.
  8. #8 Re: Rattling Supercharger
    GT Level Member rmcardle3's Avatar
    Houston, TX
    Bio, about the chipping of the piston. Would you expect a sound that ticks only can be heard starting at 1000 RPMS stopping at 1500 RPMS could be the piston or the ring? I let my brother-in-law, listen to it. He works at CAR MAX as a master mechanic. I trust him, just wondering if you have come across that same sound. Does not get loader as RPMS increase, goes OFF at 1500 RPMS and higher. Could that still be a lifter or what do you think?
  9. #9 Re: Rattling Supercharger
    a ticking could be a number of things. its best to narrow it down to one area before trying to decide what it is. lifters usually dont go bad unless theyve got a lot of miles on them, though.
  10. #10 Re: Rattling Supercharger
    Flint, MI
    So, the supercharger rattling noise is definitely the coupler? Even though it never rattles at idle and ONLY under boost?
    If this coupler is rattling under boost would it make sense that it is far less efficient when rattling?
  11. #11 Re: Rattling Supercharger
    utah
    my gtp rattles so i changed the coupler. it still sounds like rocks rattling around. any suggestions?
  12. #12 Re: Rattling Supercharger
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    Quote Originally Posted by bluevet03 View Post
    bad bearings or low on s/c oil?
  13. #13 Re: Rattling Supercharger
    Houston, TX
    Bio thanks for the quick reply. It is at 159,000 miles.
  14. #14 Re: Rattling Supercharger
    utah
    I also replaced the nose drive.
  1. supercharger rattling at low rpm
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2010, 05:15 AM
  2. rattling ass
    By 04muscle in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2009, 11:44 PM
  3. car rattling
    By jack08 in forum Audio, Security & Visual Electronics
    Last Post: 09-20-2009, 04:32 AM
  4. rattling in right rear?
    By runn141 in forum Brakes/Suspension/Chassis
    Last Post: 06-04-2009, 05:00 PM
  5. Dash Rattling
    By cboth686 in forum General Tech Discussion
    Last Post: 12-20-2008, 09:05 PM
