You could also go through driver side left of steering column, there is an empty grommet. That is depending on how much cable you have and which side you plan on running rcas, i usually run mine down the pass side.
And it might not be your radio shorting out, you could have the factory amp going, that is if you have a bose system. If thats the case i would do a 4 channel amp as well, while your already in there.
