Thread: Removing firewall grommet???
Results 1 to 5 of 5
IndeedSS Removing firewall grommet??? 09-14-2008, 12:17 PM
IndeedSS Re: Removing firewall... 09-14-2008, 02:36 PM
Reptile Re: Removing firewall... 09-14-2008, 03:36 PM
Sabrewings Re: Removing firewall... 09-14-2008, 03:41 PM
IndeedSS Re: Removing firewall... 09-14-2008, 04:41 PM
  1. #1 Removing firewall grommet???
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    In the past, I've managed to get my FP rewire poked threw and more recently inserted a 3/8 cable chase with 6 wires fed threw it. Now I need to get my WB harness fed threw the grommet as well. This time I really need to remove the grommet, slice and notch a hole large enough to house the harness.
    How the heck do you get that *&^% grommet out of it's holder? I have the top half sort of removed, but the bottom half seems to be stuck. After hours of fighting with it, I had to walk away before I got mad and made a costly mistake.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #2 Re: Removing firewall grommet???
    St Louis MO
    For anyone else:
    The grommet has two mounting tabs, one on the left and right side of the rectangle. I eventually saw these rubber ears and slit them with a razor blade. The grommet is out of the firewall, now it's time to do business.
    2010 Camaro SS LS3
  3. #3 Re: Removing firewall grommet???
    Bastard Reptile's Avatar
    Kansas City, MO
  4. #4 Re: Removing firewall grommet???
    Barksdale AFB, LA
    2009 Subaru Impreza WRX STI
  5. #5 Re: Removing firewall grommet???
    St Louis MO
    Anyone that has tried this will know how actually temping the options you two comedians posted are.
    All gauges are in and wires ran. Too tired now to screw with removing the bad O2 sensor that's been used as a WB bung plug. It seems to be stuck, but tomorrow is another day.
    2010 Camaro SS LS3
  1. Ac dripping into passenger side floor.
    By azzkikr1957 in forum General Tech Discussion
    Last Post: 06-15-2008, 10:24 AM
  2. Passenger Side Axle Seal Replacement
    By Rob3800 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-30-2008, 04:35 PM
