Thread: Firewall Pass through
Results 1 to 5 of 5
Luda Firewall Pass through 05-29-2009, 08:49 AM
CTKGP09 Re: Firewall Pass through 06-11-2009, 11:02 PM
Golgo13 Re: Firewall Pass through 06-12-2009, 12:46 AM
Luda Re: Firewall Pass through 06-12-2009, 09:47 AM
offroadfury6 Re: Firewall Pass through 06-16-2009, 05:06 PM
  1. #1 Firewall Pass through
    Springfield VA
    Just picked up my 05 Grand Prix, Im installing a Aftermarket HU, Alpine Type R 12" in a custom 5cuft enclosure, and of course the amp. now since i picked it up last night, and im at work right now, i havent gotten a chance to look under the hood and in the trunk so im Looking on recomendationson where to pass 0 Gauge wire through the firewall, preferably passenger side, but i can work with a driver side passthrough. as well as grounding locations in the trunk for an amplifier.
  2. #2 Re: Firewall Pass through
    Willoughby, Ohio
    on my 99 it was thru the passenger side...not sure about ur style tho...most likely the same tho...grounding can be done on the backseat mounts i have mine grounded by a bolt the i think goes to the bumper(its by the 3 screws that hold my taillight on) it works good
  3. #3 Re: Firewall Pass through
    Oct 2008
    mascoutah, Il
    a friend with an 04 gp made a hole on the passenger side firewall right where the carpet starts. Make sure you use a rubber grommet.
    As far as grounding, he made his own ground.
    2002 GTP
    custom HOK paint
  4. #4 Re: Firewall Pass through
    Springfield VA
    i used the massive rubber grommet in the passenger floorboard, although i cant get it to sit back in the hole with the wire there so i think i might have to drilled though the grommet and do it that way
  5. #5 Re: Firewall Pass through
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    i have an 06...peel the carpet back in the passenger floorboard, u should see where wires are coming through a hole right below the glove box. I had to go in the engine bay with a screw driver and poke the rubber boot to make it bigger so i could get the wire to fit.
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  1. firewall holes?
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 03-07-2009, 12:22 AM
  2. my 12 sec pass
    By zexed99gt in forum Track Sessions and Kills
    Last Post: 01-08-2009, 10:48 AM
  3. Removing firewall grommet???
    By IndeedSS in forum General Tech Discussion
    Last Post: 09-14-2008, 04:41 PM
  4. Boost by pass
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2008, 03:35 PM
  5. Vids of my 13.1 and 13.2 pass
    By fst in forum Track Sessions and Kills
    Last Post: 02-02-2008, 05:38 AM
