Quote Originally Posted by beaver75 View Post
What if you do replace the bulbs? The light bulb on the left side works for a short time when you first start the car then turns off. Usually when you start the car back up the light turns back on. I bent the contacts on the bulb housing just in case there was a gap. That made no difference. I am wondering if there is something wrong with the housing or the whole cluster assembly. Any thoughts?
If you're saying that you've replaced the bulbs and this is happening, then you're probably looking at bad contacts (where the prongs on the bulbs sit on the board) or possible bad tracers on the board.
