Thread: Instrument lights
Results 1 to 6 of 6
  1. #1 Instrument lights
    Somerset, Ky
    I just read the thread about losing all the dash lights and it reminded me to ask you guys about mine. This is on a 2001 GT. The left side of the tach and the fuel gague lights are out. The right side of the tach and the speedo lights are good. Are there bulbs that I can change? I remember older cars that had the black plastic bulb holders that remove with a quarter turn, replace the bulb and re-install the bulb holder. It also might mean I have a cracked PC board not getting any power to the left side instruments. Can anyone shed some light (pun) on this? Thanks!
  2. #2 Re: Instrument lights
    GTP Level Member SuperSport's Avatar
    Michigan
    Ya they are the bulbs with the plastic base that you turn. More than likely a bulb is burned out.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: Instrument lights
    Parker, Colorado
    What if you do replace the bulbs? The light bulb on the left side works for a short time when you first start the car then turns off. Usually when you start the car back up the light turns back on. I bent the contacts on the bulb housing just in case there was a gap. That made no difference. I am wondering if there is something wrong with the housing or the whole cluster assembly. Any thoughts?
  4. #4 Re: Instrument lights
    Houston
    Quote Originally Posted by beaver75 View Post
    If you're saying that you've replaced the bulbs and this is happening, then you're probably looking at bad contacts (where the prongs on the bulbs sit on the board) or possible bad tracers on the board.
  5. #5 Re: Instrument lights
    Parker, Colorado
    If that is the case is there anything that you are able to do about that without replacing the entire cluster?
  6. #6 Re: Instrument lights
    Houston
    Its up to you if you want to buy a new one or you can contact these guys and see if they can repair it. 03-06 GM Cluster Repair - GM Gauge Repair in Nevada.
  1. Impala -> GTP instrument cluster swap
    By Agentlongwood in forum Visual/Body Modifications
    Last Post: 02-15-2016, 10:29 AM
  2. instrument cluster lights
    By fasttmaxx in forum General Tech Discussion
    Last Post: 10-31-2009, 05:54 PM
  3. instrument cluster
    By 97detgp in forum General Tech Discussion
    Last Post: 06-01-2009, 09:57 AM
  4. Instrument Cluster Problem
    By skunktriscuit in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2009, 06:51 AM
  5. White Instrument Panel
    By cboth686 in forum Visual/Body Modifications
    Last Post: 04-12-2009, 08:52 PM
