What if you do replace the bulbs? The light bulb on the left side works for a short time when you first start the car then turns off. Usually when you start the car back up the light turns back on. I bent the contacts on the bulb housing just in case there was a gap. That made no difference. I am wondering if there is something wrong with the housing or the whole cluster assembly. Any thoughts?
