Thread: Are these symptoms of a bad hub assembly?
Results 1 to 11 of 11
Threaded View
  1. #1 Are these symptoms of a bad hub assembly?
    West Side Michigan
    Well my front end has been acting weird. Whenever I turn the wheel at a certain degree, I can hear my front driver wheel making a weird nose, like it's grinding or something. Today I had the wheel at that angle and had to press the brakes, and the brakes kicked back at me like ABS was engaged. It worked fine after I turned the wheel.
    Also when I backed out of my driveway today and proceeded to go, I had the wheel at this angle. The car made a weird grinding noise, and I got a Low Traction Light for some reason..
    A couple times over this winter, I just turn my car on and it has the ABS light on and then Trac is off because of it. When I turn the car off and turn it on, it's gone and then it's fine...
    Also, when I stop quickly, I feel the car around 15-10 mph, jerk forward. This is when only brakes are engaged..
    Could this affect the speed sensor and give me the random spikes in speeds in my HUD too?
    How weird..
  1. Symptoms of a bad belt tensioner
    By valleyd01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2009, 07:20 PM
  2. How to install a Hub Assembly
    By packerfanjc in forum Tires & Wheels
    Last Post: 08-25-2009, 06:31 PM
  3. Replies: 0
    Last Post: 08-24-2008, 12:43 PM
