Thread: Are these symptoms of a bad hub assembly?
Results 1 to 11 of 11
  1. #1 Re: Are these symptoms of a bad hub assembly?
    GT Level Member rolyat's Avatar
    OKC
    ^^ Drivers side is the left side.
  2. #2 Re: Are these symptoms of a bad hub assembly?
    MO
    Quote Originally Posted by rolyat View Post
    oops i meant when you're turning that way. if you turn left and it goes away then it's the left bearing??? i may have that backwards, been a while since i've messed with bearings.
    <brandonl2000> LMAO D!!
  3. #3 Re: Are these symptoms of a bad hub assembly?
    OKC
    That's correct. When you turn left up to speed it takes the weight of the left bearing so it stops grinding, and when you turn right the grinding will become a little louder indicating a bad left(driver side) wheel bearing.
  1. Symptoms of a bad belt tensioner
    By valleyd01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2009, 07:20 PM
  2. How to install a Hub Assembly
    By packerfanjc in forum Tires & Wheels
    Last Post: 08-25-2009, 06:31 PM
  3. Replies: 0
    Last Post: 08-24-2008, 12:43 PM
