Thread: How hard is it to install a plog and 3.4 pulley
Results 1 to 20 of 26
  1. #1 How hard is it to install a plog and 3.4 pulley
    MA
    I am gonna buy a plog and 3.4, but was wondering if they are a hard to install.
  2. #2 Re: How hard is it to install a plog and 3.4 pulley
    Apr 2009
    stockton ca
    plog simple and straight forward 3.4 pulley you just need a pulley puller/installer
    im guessing you also have a tune on its way and all the other supporting mods?
    I happen to have a pulley puller/installer for sale if ya want it its cheep but works
  3. #3 Re: How hard is it to install a plog and 3.4 pulley
    MA
    Quote Originally Posted by wickedintent79 View Post
    I have a 3"dp tune and cai and 180-tstat
  4. #4 Re: How hard is it to install a plog and 3.4 pulley
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    how much do you want?
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  5. #5 Re: How hard is it to install a plog and 3.4 pulley
    MA
    This a newb question, but were is the plog located?
  6. #6 Re: How hard is it to install a plog and 3.4 pulley
    MO
    PLOG is the front exhaust manifold.
    <brandonl2000> LMAO D!!
  7. #7 Re: How hard is it to install a plog and 3.4 pulley
    MA
    Quote Originally Posted by ZR1Vette09 View Post
    thanks for the answer I just hope when I install it everything goes smooth haha
  8. #8 Re: How hard is it to install a plog and 3.4 pulley
    Donating Users kfish's Avatar
    Ohio
    skip the plog and go straight to headers if your going to mod more.
  9. #9 Re: How hard is it to install a plog and 3.4 pulley
    Feb 2008
    Quote Originally Posted by kfish View Post
    Agreed. I have a P-Log setup, but wish I had just started off with headers. Even though the P-Log is very well designed, it still has to function like the factory exhaust. Headers will be a great investment if you even think you might want to mod past a basic 3.4 setup. Trust me, I am wishing I had bought headers a long time ago.
  10. #10 Re: How hard is it to install a plog and 3.4 pulley
    MA
    Quote Originally Posted by DanGTP View Post
    I would get headers, but I am only looking to to a basic 3.4 setup because I am saving up for a gto
  11. #11 Re: How hard is it to install a plog and 3.4 pulley
    Feb 2008
    It's a shame I don't have headers on the way, or I'd offer to sell you my exhaust setup...
  12. #12 Re: How hard is it to install a plog and 3.4 pulley
    Oct 2008
    Northern Illinois
    Headers are the best, I'm going dp/pl just because I'm gettng a 3" DP for free.
  13. #13 Re: How hard is it to install a plog and 3.4 pulley
    MA
    I just got the plog and I am gonna try to install it this week. I hope I can do it haha since i have no past experience modding. Also is there a how to thread on how to install one so I can have a guide line?
  14. #14 Re: How hard is it to install a plog and 3.4 pulley
    GTX Level Member real diehl's Avatar
    Salina, KS
    Quote Originally Posted by GMCARS4LIFE View Post
    Better idea:
    Skip the mods and buy the GTO...
    Depending on which series LS, you can run high 13's stock. Not going to be as easy with a GTP.
    My $.02 are in
    signature removed for inappropriate content.
    -bio
  15. #15 Re: How hard is it to install a plog and 3.4 pulley
    GT Level Member backinblackgtp's Avatar
    Nov 2009
    centereach, NY
    not a fan of GTO's or GT Slo's, they look like foreign cars, almost like a BMW, not like a sports car, but that's just one guys opinion.
  16. #16 Re: How hard is it to install a plog and 3.4 pulley
    Topeka, KS
    Well look at the front manifold. If you can figure out how to get it off you can reverse the process to get the Plog on. Its just nuts and bolts. About 8 of them. Pretty easy stuff man.
  17. #17 Re: How hard is it to install a plog and 3.4 pulley
    Apr 2008
    Bremerton, WA
    I don't know about any of you that have swapped pulleys but mine was a pain in the butt! I had the right puller/installer from "Pulley Boys" and it would of been easier to remove the snorkel and use my shop press. I measured the diameter of the shaft and the inside diameter of the removed stock pulley and the pulley was almost .0025" smaller. I've read a couple of other stories of a hard removal. I heated with a propane torch while dribbling water over the seal area of the shaft and it was still a rough removal. This totally destroys the stock pulley in the process, for what it's worth.
    My S/C snorkel seal started leaking a couple weeks later and I ended up rebuilding the snorkel with upgraded seal and coupler and used ceramic bearings which supposedly run 30% cooler. The moral of my story is; it might be worth removing the snorkel to install the new pulley and upgrade the coupler while it's off.
    I purchased "Pulley Boys" quick-change pulley system and I love it. You can purchase different size pulleys as you continue to mod and it only takes 20 minutes to change pulleys. The puller is $135 and you need to use it if your not using a shop press with the snorkel removed.
  18. #18 Re: How hard is it to install a plog and 3.4 pulley
    Feb 2008
    ZZP makes a puller that is easier to use and does not destroy a pressed-on pulley.
  19. #19 Re: How hard is it to install a plog and 3.4 pulley
    Salina, KS
    Quote Originally Posted by backinblackgtp View Post
    That's because they are foreign cars. Ever heard of Holden?
    -bio
  20. #20 Re: How hard is it to install a plog and 3.4 pulley
    in a house
    Quote Originally Posted by TMC View Post
    Ofcourse the pulley bore was smaller, its press fit. I've changed 2 on my car with no issues using zzp's puller. Maybe that pulley boys tool is crap. And ya heating the shaft would def destroy the seal.
  1. how hard it is to install viper 5701?
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-17-2009, 01:52 PM
  2. Do I need a gasket for a PLOG install?
    By nickbuol in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2009, 01:11 AM
  3. ==> H@lp Asap, TENSIONER Pulley Removal & Install <==
    By KevSorbo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2009, 08:26 PM
  4. ==> H@LP w/ TENSIONER Pulley Removal & Install Please <==
    By KevSorbo in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-30-2009, 08:14 PM
