Thread: E85 Pro's and Con's ?
Results 1 to 20 of 30
  1. #1 E85 Pro's and Con's ?
    Nov 2009
    Grand haven
    Kicking the Idea around about switching since E85 is everywhere around me. My gp is not my DD. If you are running E85 what did you do to get it RIGHT? What pulley are you running and what is your timing? I know you need the fuel pump rewire, #60 injectors , tune and a different type of fuel filter. Tell me about your exp with e85. If you dont know about this please leave this to the people that have the exp thanks.
  2. #2 Re: E85 Pro's and Con's ?
    Apr 2009
    stockton ca
    your ****ing stupid use meth or die
  3. #3 Re: E85 Pro's and Con's ?
    Apr 2009
    stockton ca
    ok no not really
    Ive been tossing the idea around too just not enough stations yet
  4. #4 Re: E85 Pro's and Con's ?
    you're a fag. no one likes you.
    go home.
    Oh wait... you're probably home.
    OH WAIT, wrong person.
    E85>meth if you have access to it.
    ZE END.
  5. #5 Re: E85 Pro's and Con's ?
    Nov 2009
    Grand haven
    Matt is drinking again ^^^^^ LMAO
  6. #6 Re: E85 Pro's and Con's ?
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    e85 is like 6:1 air fuel for a good mix... terrible terrible fuel mix will result in even worse gas mileage..
    run meth and 94 octane aand you can reach for the stars... i wont even consider e85 although its near me
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  7. #7 Re: E85 Pro's and Con's ?
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by kuntzie View Post
    e85 is like 6:1 air fuel for a good mix... Terrible terrible fuel mix will result in even worse gas mileage..
    Run meth and 94 octane aand you can reach for the stars... I wont even consider e85 although its near me
    lol lol lol lol lol lol...
    Lol.
  8. #8 Re: E85 Pro's and Con's ?
    94 octane isn't availible in most places... but it is REALLY common around here though.
    Gotta love Ultra 94.
  9. #9 Re: E85 Pro's and Con's ?
    Apr 2009
    stockton ca
    All we have is 87 89 91 here unless 8 bucks a gallon seems fair and for that we have 100
  10. #10 Re: E85 Pro's and Con's ?
    94 is basically 12 cents more per gallon versus 91 octane. its quite the steal really.
    Drinking is fun
  11. #11 Re: E85 Pro's and Con's ?
    Feb 2010
    well technically 94 octane is E10- 91 with 10% ethanol.... so you could always put in 1/8 of a tank of e85 and you will make a 94 octane.
  12. #12 Re: E85 Pro's and Con's ?
    Apr 2009
    stockton ca
    so i just need 100 gallon reserve tank of e85 and just add a couple gallons to my 91 before track time lol
  13. #13 Re: E85 Pro's and Con's ?
    basically.
    Hence people having mixed results in switching between shell 91 and sunnoco/petro 94.
  14. #14 Re: E85 Pro's and Con's ?
    did i not have this conversation with you already? you need to review the interwebs, homie.
  15. #15 Re: E85 Pro's and Con's ?
    Donating Users Tengis's Avatar
    Houston
    e85 is like 6:1 air fuel for a good mix... terrible terrible fuel mix will result in even worse gas mileage. Run meth and 94 octane aand you can reach for the stars... i wont even consider e85 although its near me
    By not considering E85 you are doing yourself a disservice. Ive got multiple local cars getting 20+ MPG on E85 open loop tuned 3800s. Also, the max power AFR of E85 is more broad then pump gas... not to mention its more forgiving if you were to have fueling issues that make you go lean (you probably wouldnt blow up).
    E85 in standard engines - Wikipedia, the free encyclopedia
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  16. #16 Re: E85 Pro's and Con's ?
    GT Level Member BoostedComp's Avatar
    Youngstown
    i would loooove to run e85. but with how much driving i do, its my daily, and the fact that the closest one to me is 20 min away and after that about an hour... its just not practical at the moment. its good stuff, just not popular in my area yet sadly.
  17. #17 Re: E85 Pro's and Con's ?
    Nov 2009
    Grand haven
    Anyone else want to add to this?
  18. #18 Re: E85 Pro's and Con's ?
    do it if you have access to a fair amount of stations to stop at.
  19. #19 Re: E85 Pro's and Con's ?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    If its available run it. I wish I had it available here.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  20. #20 Re: E85 Pro's and Con's ?
    Apr 2009
    stockton ca
    wnder how fbody's and lt1's respond to it
con, e85, pro
