Thread: Header and manifold Thread
Results 1 to 20 of 325
Threaded View
  1. #11 Re: Header and manifold Thread
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Quote Originally Posted by GrandPrixGTP1 View Post
    so after reading everything im still confused to as what you all need for speed daddy headers.
    If you get em in the mail what are the things you need to buy?
    "band clamps" ,
    And so they do have a U-Bend? it doesnt say it as a "con" for SD headers so i was confused.
    Sorry still a newb at this header stuff. lol.
    I have no idea what to buy, cause they all have problems.
    Also.. do i need to buy a dp with cat?
    or can i just buy a new highflow cat that can be welded onto the pipe?..
    From what I have understand (don't have these on yet but near future):
    1. Band clamps are better than the U clamps that come with SD headers.
    2. The gaskets that come with the headers are not great quality, so consider better ones.
    3. Buy sealant regardless.
    4. The SD header flex is bad, but you could use it until it fails. When replacing use a 3" interlock & braided flex only.
    5. The SD headers have a U Bend, which is 3" and flows fine, but it will drag on the ground like a dachshunds nuts if you are not careful or if the car is lowered.
    6. The headers package comes with sufficient tubing to replace the factory catalytic conv. This also elminates the factory U bend (not the headers U-bend). If you want to run a cat, consider buying a magnaflow 3" cat for $60. Headers can also mate to the stock cat, but the factory U bend is after the cat and should then be eliminated if not already done so.
    Additional: Removing the factory catalytic modifications should be coupled to a reprogrammed PCM with provision for this (according to what I have read).
    Hope this helps.
  1. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  2. Another header thread just what we need...
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 11-09-2009, 12:18 AM
  3. S&S Header Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 09:57 PM
  4. SLP header fitment
    By 01goldgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 07:08 PM
  5. spilling oil on header
    By crshoveride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2008, 06:56 PM
