Thread: Header and manifold Thread
Page 9 of 17 FirstFirst ... 7891011 ... LastLast
Results 161 to 180 of 325
  1. #1 Re: Header and manifold Thread
    Charles City, IA
    Least problems would be S&S as far as the install.
    SMGPFC Two Nipple General
  2. #2 Re: Header and manifold Thread
    quoted for 100% truth. LOVED these headers.
  3. #3 Re: Header and manifold Thread
  4. #4 Re: Header and manifold Thread
    Ottawa ON, Canada
    how good are the "Other Guys" Headers?.
    They look pretty good and all. anyone had em..? problems?
    The Other Guys Exhaust Headers: 3800 Performance
    _______________________
    2002 Acura Rsx Type S - K20A2
  5. #5 Re: Header and manifold Thread
    probably one of the best sets you can buy for the 3800. the problem with them is that they will end up warping the flanges if you end up overtighten them. otherwise they usually seal very well and are one of the better designed sets.
  6. #6 Re: Header and manifold Thread
    Charles City, IA
    They are the tog headers. tog= the other guys
  7. #7 Re: Header and manifold Thread
    Jul 2010
    bettendorf ia
    03 pontiac grand prix gtp limited edition
    02 chevy silverado 4x4
    97 pontiac sunfire
    87 ford mustang notch 408 stroker
  8. #8 Re: Header and manifold Thread
    Speed daddy's.... but they're WAY overpriced.
  9. #9 Re: Header and manifold Thread
  10. #10 Re: Header and manifold Thread
    Ottawa ON, Canada
    so really pacesetters seem like there a good buy (ceramic coated),
    and the TOG headers.?
    I want to get headers within the next while:P. so i need an opinion but it seems like everyone likes there own :P.
    and ps.
    2.5" or 3" Piping for exhaust?
    I have aftermarket flowmasters and im not even sure what the piping size is (cause i bought the car with the setup on it). prob 2.25 or 2.5 but its older so i might just replace it all to new piping when doing headers. if its 2.25 i prob will replace, just with what.. 2.5 or 3?
  11. #11 Re: Header and manifold Thread
    Charles City, IA
    I would go 2.5 to the y then 2.25 to the mufflers. Speed daddys are the best buy if you have a shop fix the dp.
  12. #12 Re: Header and manifold Thread
    Nov 2009
    MN
    You really do not need to take out the "u bend" unless you are lowered, otherwise it is fine. I really don't know what all that fuss is about. Speed daddys sealed up nice on my 04 gtp comp g and I've been running them fine. Reduced a lot of knock and I sealed them up with some RTV/4 Easy Seal Napa band clamps. Heck, even in 2-3 years if the stainless goes bad I could always buy 2 other sets for cheaper then buy ZZP's. They are the best price/hp ratio for headers. The problem I see with them is not what others have mentioned, but when under heavy acceleration in reverse it hits on my 04. I believe this is true for most 04+'s as they do not have much room for any headers in that rear tunnel. Also they come very close to the front fan motor but that was easily fixed with a spot fix of header wrap. Both of those issues are very small, unless if you were someone who must floor it in reverse a lot.
    04 GTP Comp G/Inferno Package/PFYC Tips/K&N Custom Intake/AL104's/
    180*/ S/D Headers /3.6" MPS /Tuned/Aeroforce Interceptor
    My old 02 GT http://img.photobucket.com/albums/v3...9/DSCI0182.jpg
  13. #13 Re: Header and manifold Thread
    GT Level Member Whitehispanic's Avatar
    Westborough
    This is exactly what i am running.
    *sig too tall*
  14. #14 Re: Header and manifold Thread
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    i have speed daddys and i love em. took about 8 hours to install because it was pain in the ass getting the back ones in place but once they were it was too easy
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  15. #15 Re: Header and manifold Thread
    Or get a bung welded in on the crossover for your front O2 then another bung welded on your DP for a wideband if needed.
  16. #16 Re: Header and manifold Thread
    SE Level Member MADGTP's Avatar
    Nov 2010
    Toms River NJ
    Got my SD headers Friday. Just read this thread all the way threw. So went out to the garage and did a mockup of the headers,on a short block. They fit together well. I like the look of the band clamp better. Now about the rtv, do you put it inside the slip joint. The gaskets are sh&t and willbe getting new ones. The bolts holes line up good, but the port holes do not. I built a few muscle cars back in the 70's and 80's and to get an edge you had to p/p everything to fit perfect.
  17. #17 Re: Header and manifold Thread
    Charles City, IA
    Yeah rtv inside the slip joints.
  18. #18 Re: Header and manifold Thread
    SE Level Member RickyRacer21's Avatar
    York, PA
    whats your guys opinion on open header? gain or lose hp? Cars being using as a oval dirt track race
  19. #19 Re: Header and manifold Thread
    im not sure that you'd realistically lose power, but its going to be so god awful loud that you're going to rip your hair out. at least put piping all the way back so you dont go deaf.
  20. #20 Re: Header and manifold Thread
    Charles City, IA
    I would just run a 12" glass pack where the car should be and then a turn down.
  1. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  2. Another header thread just what we need...
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 11-09-2009, 12:18 AM
  3. S&S Header Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 09:57 PM
  4. SLP header fitment
    By 01goldgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 07:08 PM
  5. spilling oil on header
    By crshoveride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2008, 06:56 PM
