Thread: Header and manifold Thread
Page 1 of 17 12311 ... LastLast
Results 1 to 20 of 325
  1. #1 Header and manifold Thread
    Charles City, IA
    Here is a list of headers that fit our cars Issues with them and what not. Also info on the plog and dp combo.
    Note: All headers for 97-03 will also fit 04+ cars, except obx they fit nothing with out modification.
    This is what you want for clamps for the cross over. Band clamp http://www.fixthisride.com/img_parts...22_33272_i.jpg
    Install write up for speed daddy/ssac http://www.grandprixforums.net/speed...eup-32920.html
    You will also need to extend the front 02 sensor harness with all headers except for zzp headers with the 02 bung in the cross over.
    Speed Daddy $220 http://cgi.ebay.com/ebaymotors/97-03...item27ae5dd4f4
    Pros: direct copy of SSAC headers,cheap
    Cons: slip fits, 02 sensor hits floorboard on some cars.
    ZZP HEADERS starting at $689 found at ZZPerformance
    Pros: They are stainless steel, 2 piece with one slip joint for the cross over,1.75" primaries.
    Cons: some have issues with contact with fans, very pricy.
    TOG HEADERS starting at $749 found at 3800 Performance - high performance aftermarket car parts for your Grand Prix, Monte Carlo, Impala, Regal, Bonneville, and V6 F-body!!
    Pros: No slip joints, stainless steel, 1.75" primaries,Tog extremes have huge primaries for extreme builds.
    Cons: Have to be welded in most expensive in the group.
    SLP Headers starting at $689 also found at 3800performance
    Pros Stainless steel, 1 5/8" primaries
    Cons Have to be welded in, have leaky flex section.
    S&S Headers starting at $664 found at HeaderMania.com - Home Of S&S Headers Online Store
    Pros: Two pice design with no slip joints. Very easy to seal.
    Cons: 2.5" dp,1.5" primaries, have to weld in dp
    Pacesetter Headers starting at $349 found at W Body Store and others
    Pros: 1.75" primaries, can be bolt in
    Cons: Most have sealing issues, mild steel, most have them welded
    http://www.grandprixforums.net/f73/l...ion-16085.html
    SSautochrome headers $299 found at Turbo Kits, Turbo Manifolds, Import Performance Products, SSAutochrome Inc.
    Pros: cheap, stainless steel,1.75" Primaries,3"dp complete bolt in
    Cons: 2 slip joints on cross over, U bend in dp, some had issues with 02 sensor contacting floor of car
    OBX and other ebay headers $299 found at eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
    Pos: Stainless steel, 1.75" primaries
    Cons: Cross over is built wrong and has to be cut and rewelded, 2.5" down pipe.
    Non header exhaust options
    Plog starting at $179 found at ZZPerformance
    Pros can be used for turbo set up, easy install, cheap
    Cons does not flow as well as headers, only replaces front manifold
    Ported manifolds buy a dremel and do them your self
    Pros: Pretty much free
    Cons: Offers the least amount of flow
    Down pipe starting at $89 found from most vendors
    Pros: replaces restrictive factory dp, bolt in, easy install
    Cons: can not be used with headers
    Speedy daddy/SSAC headers with the down pipe fixed. (Thatks to Silver GTP for the pics and write up)
    Here's a summary of what it took to make it: I bought a new v-band clamp with flanges off e-bay for about $25 iirc. The high flow cat and flex came from ZZP for about $100. All the piping used came from the original downpipe. The rear header was cut just after the collector (the top of the original flex). The short, straight pipe was cut and welded onto the end of the cat. The slip fit right before the rear O2 was kept in place allowing the cat to be slid out of the rear half of the exhaust. The new flex was welded onto the front of the cat. A short piece of straight pipe was welded on after the collector and a bung was added for the wideband. The part of the stock sink trap with the v-band was cut off at the angle needed to match up to the new flex and welded on. One of the flanges from the new v-band was welded to the bottom of the rear header. Everything was then installed. I also cut the crossover and put a flex in since the ends of it don't slide straight in the way it's made. Band clamps were placed at the 3 slip joints that are left.
    Most choose to delete the egr system when installing headers. The pros to this are eliminating chances of exhaust leaks, less build up of carbon in the intake manifold, prettier engine bay. The cons, you will lose 2-3 mpg on the highway unless you get a custom tune with higher timing in the cruise cells. The way most delete the egr system is to cut the tubes coming form the egr base and remove the mounting flanges for the LIM and exhaust manifold. Then by inserting a penny in one and a nickel in the other and using some copper RTV to help seal it bolt the flange to the intake and header respectively. I chose a different way. I cut off the egr tube on the header and welded the hole shut on the primary and filled the mounting flange that goes on the intake.
    Most headers have a ceramic coated option. This coating helps retain heat and prevents rust. Not completely necessary, recommended for mild steel headers. If anyone sees any miss information, or has more please post and I will add it. Please no pissing match on who's headers are the best. This is just an informational thread.
    Last edited by TheOtherNick; 12-05-2010 at 05:42 PM. Reason: added more info *****es
    SMGPFC Two Nipple General
  2. #2 Re: Header and manifold thread Thread
    Apr 2009
    stockton ca
    nice write up But you know there will still be daily/weekly threads about what is better
  3. #3 Re: Header and manifold thread Thread
    MO
    i hadn't heard that the SSAC have the U-bend. Why do so many guys recommend them if it's no good?
    <brandonl2000> LMAO D!!
  4. #4 Re: Header and manifold thread Thread
    Charles City, IA
    Quote Originally Posted by ZR1Vette09 View Post
    They are fine. The U bend is 3" they flow fine. I run them.
  5. #5 Re: Header and manifold thread Thread
    MO
    granted i was curious too because the 04+ don't have the u bend
  6. #6 Re: Header and manifold thread Thread
    swift current,sask.
    Sticky??
  7. #7 Re: Header and manifold thread Thread
    Charles City, IA
    It is in the design of the rear header. The flex is built into the rear header causing it to extend down lower and the bend brings it back up. You could fix this by cutting off the flex and welding in some pipe to bring it level with the rest of the exhaust and put the flex section where the cat would normally be or you can be lazy like me and leave it. I only have access to a exhaust pipe bender at work why would I change it lol.
  8. #8 Re: Header and manifold thread Thread
    GT Level Member Joe m's Avatar
    mesa,az
    Cons: 2 slip joints on cross over, U bend in dp, some had issues with 02 sensor contacting floor of car--- ssac
    i didnt know they came with a u-bend. but you say they still flow good with it there? so are they still recomended or should i save for diffrent?
  9. #9 Re: Header and manifold thread Thread
    Charles City, IA
    They flow fine. Bio ran S&S headers with the 2.5" dp on a rocker meth 3.2 setup and probably still had plenty of room to breath. I will get under my car and take a pic of the bend. It is no where near what the factory u-bend is.
  10. #10 Re: Header and manifold thread Thread
    mesa,az
    ok cool. was just curious cuz im ordering my ssac's next week and didnt know about the u bend kinda dont want to change plans and wait longer lol. but if you say the flow is good then bring it on.
  11. #11 Re: Header and manifold thread Thread
    West Side Michigan
    Thanks for this, no joke. Very nice info. Now I know what to get.. I'm thinking SSAC Headers.. but not now of course..
  12. #12 Re: Header and manifold thread Thread
    Donating Users kfish's Avatar
    Ohio
    this is the ssac's U bend:
  13. #13 Re: Header and manifold thread Thread
    Apr 2009
    stockton ca
    That ubend just isnt that big of a deal at all ssac's are best value
  14. #14 Re: Header and manifold Thread
    Donating Users blowfishRus6's Avatar
    g.a.
    dang how much stuff do you drag that u bend on?????? haha.
    to add to it, if you dont want to weld the headers there is good band clamps that will get the job done.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  15. #15 Re: Header and manifold Thread
    Charles City, IA
    I have a few scrapes on mine. Nothing major.
  16. #16 Re: Header and manifold Thread
    Apr 2009
    stockton ca
    What is the best band to use with ssac's? links maybe
    I havent looked yet since i dont have them yet but i was curious
  17. #17 Re: Header and manifold Thread
    Charles City, IA
    I just went to car quest and asked for some band clamps. Get some stepped ones.
  18. #18 Re: Header and manifold Thread
    g.a.
    its slow.
  19. #19 Re: Header and manifold Thread
    GT Level Member rmcardle3's Avatar
    Houston, TX
    Quote Originally Posted by blowfishRus6 View Post
    Blowfish, how many clamps total did you need. I saw the one band clamp. On which seem did you place it?
  20. #20 Re: Header and manifold Thread
    Charles City, IA
    Yes those will work fine. Just dont get any of the really skinny ones.
  1. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  2. Another header thread just what we need...
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 11-09-2009, 12:18 AM
  3. S&S Header Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 09:57 PM
  4. SLP header fitment
    By 01goldgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 07:08 PM
  5. spilling oil on header
    By crshoveride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2008, 06:56 PM
