Thread: Header and manifold Thread
Page 11 of 17 FirstFirst ... 910111213 ... LastLast
Results 201 to 220 of 325
  1. #201 Re: Header and manifold Thread
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Quote Originally Posted by GrandPrixGTP1 View Post
    so after reading everything im still confused to as what you all need for speed daddy headers.
    If you get em in the mail what are the things you need to buy?
    "band clamps" ,
    And so they do have a U-Bend? it doesnt say it as a "con" for SD headers so i was confused.
    Sorry still a newb at this header stuff. lol.
    I have no idea what to buy, cause they all have problems.
    Also.. do i need to buy a dp with cat?
    or can i just buy a new highflow cat that can be welded onto the pipe?..
    From what I have understand (don't have these on yet but near future):
    1. Band clamps are better than the U clamps that come with SD headers.
    2. The gaskets that come with the headers are not great quality, so consider better ones.
    3. Buy sealant regardless.
    4. The SD header flex is bad, but you could use it until it fails. When replacing use a 3" interlock & braided flex only.
    5. The SD headers have a U Bend, which is 3" and flows fine, but it will drag on the ground like a dachshunds nuts if you are not careful or if the car is lowered.
    6. The headers package comes with sufficient tubing to replace the factory catalytic conv. This also elminates the factory U bend (not the headers U-bend). If you want to run a cat, consider buying a magnaflow 3" cat for $60. Headers can also mate to the stock cat, but the factory U bend is after the cat and should then be eliminated if not already done so.
    Additional: Removing the factory catalytic modifications should be coupled to a reprogrammed PCM with provision for this (according to what I have read).
    Hope this helps.
  2. #202 Re: Header and manifold Thread
    Ottawa ON, Canada
    Thank you.
    but in the end, after buying a new flex, a cat, better band clamps, gaskets etc.
    wouldnt it be better just to buy a more expensive header with less problems and better fitment?
    _______________________
    2002 Acura Rsx Type S - K20A2
  3. #203 Re: Header and manifold Thread
    Well if you can get your SD's fixed for $400 thats still better than 600+ for used ZZP's.
  4. #204 Re: Header and manifold Thread
    $200 for re-done DP?
    youz mad.
    I'd say $50 bucks tops....since all they are doing is cutting out the gooseneck and welding in a piece of straight pipe. Plus...if you have great motor mounts...you don't even need a flex.
  5. #205 Re: Header and manifold Thread
    E-test cat is 90+ shipping.
    ZZP flex costs some money as well...
    Then theres the RTV and better clamps.
    it adds up yo.
  6. #206 Re: Header and manifold Thread
    SE Level Member teedysfastGT's Avatar
    wisconsin
    Well ive been looking around for headers for awhile here and I have seen them on a lot of gtps but I have a gt and was wondering if they will still fit if the header says it made for a gtp. Thanks
  7. #207 Re: Header and manifold Thread
  8. #208 Re: Header and manifold Thread
    SE Level Member Cowboysfan22's Avatar
    Jun 2010
    Iowa
    `I plan on getting some sd headers here shortly and keeping everything stock after that. With the right supporting mods would I be able to drop a pulley size if I wanted to or no?
  9. #209 Re: Header and manifold Thread
    Never Never Land
    youz mad.
    Define great. Like, solid or what?
  10. #210 Re: Header and manifold Thread
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    like a solid rubber one ide imagine
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  11. #211 Re: Header and manifold Thread
    yea solids, and poly uppers or something like that, minimal engine movement is what you want, but a smidge is ok.
  12. #212 Re: Header and manifold Thread
    Nov 2010
    south east AZ
    i think ill have my exhaust shop do that for me, cut out my flex and the u bend, hell weld up all the joints while they're at it
    01 T/A WS6-SOLD
  13. #213 Re: Header and manifold Thread
    GT Level Member Xanthous's Avatar
    Apr 2011
    St. Louis
    Do the SD headers have 1.75" primaries?
  14. #214 Re: Header and manifold Thread
    Apr 2011
    St. Louis
    Also SSAC only wants $225 for their headers shipped.
    Pontiac Performance Racing Products for International Sales from SSAutochrome Inc.
  15. #215 Re: Header and manifold Thread
    Jul 2010
    bettendorf ia
    if you cut the flex out and welded a bend in it would you still be able to get the header out?
    03 pontiac grand prix gtp limited edition
    02 chevy silverado 4x4
    97 pontiac sunfire
    87 ford mustang notch 408 stroker
  16. #216 Re: Header and manifold Thread
    What do you mean by get it out? If you lower the subframe a little..I think you could still put it in or out with the pipe being solid. the flex doesn't help get it in.
  17. #217 Re: Header and manifold Thread
    Apr 2011
    St. Louis
    Why does the original post say the sd headers are a direct copy of the ssac headers if the sd headers have 1.5" primaries and ssac have 1.75?
  18. #218 Re: Header and manifold Thread
    May 2011
    ohio
    i was wondering the same thing.
  19. #219 Re: Header and manifold Thread
    Charles City, IA
    Speed daddies are 1.75" primaries.
    SMGPFC Two Nipple General
  20. #220 Re: Header and manifold Thread
    got i quick downpipe question,
    downpipes for the 3.8s wont work for a 3.1 or a 3.4?
    i dont they will, but i thought i ask just to be sure
    SMGPFC Member #10
  1. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  2. Another header thread just what we need...
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 11-09-2009, 12:18 AM
  3. S&S Header Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 09:57 PM
  4. SLP header fitment
    By 01goldgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 07:08 PM
  5. spilling oil on header
    By crshoveride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2008, 06:56 PM
