Thread: Electrical Problem!! need help asap
Results 1 to 5 of 5
  1. #1 Electrical Problem!! need help asap
    Feb 2009
    west pittston pa
    ok i have a 2003 gt and ive been having problems with the eclectrical it started with the i would put the heat on or the air and my headlights would turn off then it started to get worse ..now my heat wont work at all really but sometimes it will go on the hghest setting SOMETIMES! .. the rear defrosters wont turn on aas well.. and when the heat and stuff doesnt work i have 2 turn my headlight on automatically or they wont come on.. and when i try 2 use the heat you can sometimes hear a clicking sound coming somewhere from the dash and then it turrns the headlights off. and another thing me heated seat wouldnt turn opff one day and was reallly hott like about to butn my seat so i had to take the fuse out,,does anyone have a clue what is going on??
  2. #2 Re: Electrical Problem!! need help asap
    MO
    have an auto electrical shop test the body control module. You kind of have to start at the source for where all these different things connect
    <brandonl2000> LMAO D!!
  3. #3 Re: Electrical Problem!! need help asap
    Wausau, WI
    I have also heard of the ignition wiring causing all of this and more weird things to happen. It very well could be the ignition.
  4. #4 Re: Electrical Problem!! need help asap
    PA
    My first thought would be a bad ignition switch. Parts are about $50 from Morad and takes an hour or two to change. I would start there.
    2001 GSE
  5. #5 Re: Electrical Problem!! need help asap
    Feb 2009
    west pittston pa
    k thanks.. and ya i forgot to mention that my key sometimes doesnt wanna come out and i just pull it out and it like half way turned so maybe thats what it is
  1. Headlight/electrical problem
    By skunktriscuit in forum General Tech Discussion
    Last Post: 08-28-2010, 02:55 AM
  2. 98 Grand Prix Electrical problem
    By soulmonger in forum General Tech Discussion
    Last Post: 07-01-2009, 04:10 PM
  3. Electrical Or Fuse Problem For Fog Lamps ...
    By G8GTChick in forum General Tech Discussion
    Last Post: 05-24-2009, 08:10 PM
  4. Electrical problem
    By black98gt in forum General Tech Discussion
    Last Post: 12-09-2008, 02:02 AM
  5. Have an electrical Dash problem!!
    By Padawan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2008, 09:42 PM
