Thread: Key FOB Coding-Reprogramming
Results 1 to 6 of 6
  1. #1 Key FOB Coding-Reprogramming
    SE Level Member CVM116's Avatar
    Millstone Twp NJ
    I have a spare GM key FOB I would like to try and Code for my '04 GP GT1. The owners manual says to take it to a dealer - but the Forum must know the secret!
    Thanks in advance
    Charlie
  2. #2 Re: Key FOB Coding-Reprogramming
    I live here. UR LOSN's Avatar
    Rockford, IL
    moved to correct forum.
  3. #3 Re: Key FOB Coding-Reprogramming
    Wausau, WI
  4. #4 Re: Key FOB Coding-Reprogramming
    Aug 2008
    KCMO
    the 04+ you have to take to the dealer cuz it through the bcm and i have tried the only 2 ways there is to program them. the only 2 ways only work on the 97-03's. it 53 dollars and they will do up to 4 remotes
  5. #5 Re: Key FOB Coding-Reprogramming
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    U use a tech2 to program it, your best bet is go to a local shop, could be cheaper and get it done (if they have 1) if not the dealer will
  6. #6 Re: Key FOB Coding-Reprogramming
    Millstone Twp NJ
    Thanks Guys!
  1. Pcm reprogramming
    By Joe Cabras in forum PCM Tuning
    Last Post: 09-14-2009, 03:33 PM
