Thread: 06' GXP Sound System Help
Results 1 to 15 of 15
  1. #1 Re: 06' GXP Sound System Help
    New Brunswick
    Everything comes from the stereo (LF,RF,RR, RL) in low level and goes to the amp, the amp then takes this and sends the bass and the highs to the proper speakers.
    Im not sure of a way to get around this, but im thinking maybe specialized places like stereo shops may have an adapter to combine the two out puts from the amp into one...I will look on monday for some diagrams and info on the operation of this system so you can get an idea of how it works and such.
  2. #2 Re: 06' GXP Sound System Help
    Minnesota
    Had a very similar problem with a lack of bass, with the stock monsoon head unit. After days of searching finally called a dealer and got a wiring diagram for the plugs into the amp. I have an 04 Grand Prix GT, not 100% sure the amp is the same, but it most likely is, maybe this will help
    (Smaller Plug)
    Pin A/Lt Grn - Right Front Speaker Output +
    Pin B/DK Grn - Right Front Speaker Output -
    Pin C/Gray - Left Front Speaker Output -
    Pin D/Tan - Left Front Speaker Output +
    Pin E/ Orange - Battery +
    Pin F/Black+White - Ground
    Pin G/Yellow - Front Center Speaker Output +
    Pin H/Lt Blue - Front Center Speaker Output -
    (Larger Plug)
    Pin A1/Gray+Black - Amp. Present Signal
    Pin A2 - NOT USED
    Pin A3/Purple - Radio On Signal
    Pin A4/Brown+White - Left Rear Low Level Signal +
    Pin A5/Brown - Left Rear Low Level Signal -
    Pin A6/Dk Grn - Left Front Low Level Signal -
    Pin A7/Tan - Left Front Low Level Signal +
    Pin A8/Tan - Amplifier Control
    Pin A9/Dk Blue - Right Rear Speaker Output +
    Pin A10/Lt Blue - Right Rear Speaker Output -
    Pin A11/Brown - Left Rear Speaker Output +
    Pin A12/Yellow - Left Rear Speaker Output -
    Pin B1/Lt Green+Black - Rear Subwoofer Output -
    Pin B2/Dk Blue+White - Rear Subwoofer Output +
    Pin B3 NOT USED
    Pin B4/Black - Right Rear Low Level Signal -
    Pin B5/Dk Blue - Right Rear Low Level Signal +
    Pin B6/Lt Green+White - Right Front Low Level Signal +
    Pin B7/Lt Green - Right Front Low Level Signal -
    Pin B8 NOT USED
    Pin B9/Black - Left Front Tweeter Output +
    Pin B10/Yellow - Left Front Tweeter Output -
    Pin B11/Lt Green - Right Front Tweeter Output +
    Pin B12/Purple - Right Front Tweeter Output -
  3. #3 Re: 06' GXP Sound System Help
    Dec 2012
    Knoxville, TN
    Michael, it's been a while but... I'm up against it too. Did you uncover any way around the 4-wire (mid and bass) outputs from the monsoon amp to an aftermarket, 2-wire speaker without hacking up the speaker?
  1. Finally got my Sound System together the way I wanted it!!!
    By GeddyLee in forum Audio, Security & Visual Electronics
    Last Post: 08-10-2009, 04:14 PM
  2. sound system blueprint/conception
    By Derek in forum Audio, Security & Visual Electronics
    Last Post: 05-28-2009, 10:51 PM
  3. Starting to build my sound system
    By Nick22 in forum Audio, Security & Visual Electronics
    Last Post: 01-28-2009, 05:24 PM
  4. S/C Sound
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 11-18-2008, 10:33 PM
  5. Need help with Monsoon sound system please
    By Keith04gp in forum General Tech Discussion
    Last Post: 09-29-2008, 04:51 PM
