Thread: 01 GTP shakes while accelerating. HELP!
Results 1 to 13 of 13
  1. #1 01 GTP shakes while accelerating. HELP!
    SE Level Member 01STOCKGTP's Avatar
    Nov 2010
    Michigan
    I have an 01 stock GTP. It has recently started shaking while under moderate acceleration especially when I have several people in the car. Any ideas on what might be causing the problem? THANKS!
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Cv axle. Just replace both.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  3. #3 Re: 01 GTP shakes while accelerating. HELP!
    Nov 2010
    Michigan
    Quote Originally Posted by Sushamouf View Post
    Sent from my Droid
    When I got new tires a couple months ago Bell Tire did mention I had a CV Joint going out. They also mentioned a tie rod needing to be replaced. Would that be at all related and cause the symptoms as well? Out of curiosity why do you recommend replacing both?
    Thanks
    May 2011
    United States
    Tie rod end most likely isn't contributing to the oscillation, but still worth replacing then doing alignment. When the CV joint wears out it can have play in the joint, so when you apply torsional load to the joint/shaft it creates an unbalance and thus your wobble. But when the load is reduced on the axle, it returns to center and is balanced. That is why it only shakes on accel. I had the same issue when I purchased my GTP. I recommend both, just because I like to do thi gs in pairs. Chances are if one is going bad, the other is on it's way.
    Sent from my Droid
  5. #5 Re: 01 GTP shakes while accelerating. HELP!
    Nov 2010
    Michigan
    Sent from my Droid
    Any recommendations on what brand of cv axle? What am I looking at for the pricetag of this fix? Would you recommend me doing this myself? Any good writeups that you know of?
    May 2011
    United States
    I would recommend acdelco. Reman shafts are kinda luck of the draw. Not sure on price. If you can do your own brakes, you could probably tackle this with a write up. You could try the search, i don't know of any write ups off hand.
    Sent from my Droid
  7. #7 Re: 01 GTP shakes while accelerating. HELP!
    Nov 2010
    Michigan
    Sent from my Droid
    Alright thanks. I appreciate the help!
  8. #8 Re: 01 GTP shakes while accelerating. HELP!
    new york
    how do you check the cv axles i changed the drivers side awhile back and now have a vibration again
  9. #9 Re: 01 GTP shakes while accelerating. HELP!
    St. Louis
    You can visually check them by looking at the boots on the inner and outer joints. If they are wet or slinging grease everywhere then that's the one to change. The only way I found I had a bad pass. side inner joint was by accident. I leaned on the shaft while doing something else under there and heard a clunk. Pressing down on the shaft showed I had play in the inner joint that was causing a horrible vibration on accel and any speed above 50.
  10. #10 Re: 01 GTP shakes while accelerating. HELP!
    Nov 2010
    Michigan
    Quote Originally Posted by FordMan77 View Post
    My mechanic thinks that it is a back motor mount that is causing the CV axel to be off causing the vibration. what do you think about this?
  11. #11 Re: 01 GTP shakes while accelerating. HELP!
    St. Louis
    It could very well be the motor and trans. mounts. If it is sitting lower than required the axle geometry will be off, thus causing a vibration. If you take a look at your motor mount (under the balancer area) and see a bunch of black liquid goo then your mount has failed, as they a fluid filled from the factory.
    FYI- There is no "back" motor mount on these cars. There is a motor mount up front under the balancer, a trans mount on the drivers side (under the trans, duh, lol..) and the 2 dogbone mounts you see when you open the hood.
  12. #12 Re: 01 GTP shakes while accelerating. HELP!
    SE Level Member EricGTP's Avatar
    Apr 2009
    Kansas City
    Ford man is correct, was lowered on intrax once and shook after the install. Took the motor mounts out and they were toast. New mounts fixed it. That is of course if you are lowered.
    BTW if your replacing one, Might as well replace both. Drivers side mount is the trans mount. The passenger side mount usually looks the worse depending on oil leaks and such.
    2001 GTP XP cam, powerlog, F body brakes, DIY shift kit
  13. #13 Re: 01 GTP shakes while accelerating. HELP!
    SE Level Member Futures Passed's Avatar
    Dec 2011
    Florida
    I've got an SE that had the same problems and the same fixes. The CV got ripped up from the motor mount failing. It's right below the belt side of the engine, so if your crank seal has any kind of leak going, the oil will drip down and eat away at the rubber in the motor mount.
    Another sign you may have a bad engine mount is when you shift from reverse to drive, or from drive to reverse, you hear a clunk sound under the hood.
  1. My GTP Shakes When Accelerating.. Please Help
    By Supercharged03GTP in forum Brakes/Suspension/Chassis
    Last Post: 05-10-2012, 08:20 AM
  2. car shakes
    By valrathe in forum General Tech Discussion
    Last Post: 11-03-2010, 06:28 PM
  3. 02 GP Shakes upon accelerating
    By riddell87 in forum General Tech Discussion
    Last Post: 01-08-2010, 11:11 PM
  4. gtp shakes/ vibrates
    By backinblackgtp in forum General Tech Discussion
    Last Post: 12-13-2009, 01:42 AM
  5. Car shakes after lowering
    By Smokedgtp in forum Brakes/Suspension/Chassis
    Last Post: 04-30-2008, 09:17 PM
