Thread: plugs
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #1 Re: plugs
    Quote Originally Posted by OH4CompG View Post
    I want your 3.4 when you blow it up from going wot with knock
    And running a 3.4" on a Gen V'ed car is going to be needing headers and a slew of other mods...WAY more than a Gen III car like he has. Good luck...I'll buy it from you after you blow up your car and use it as a paperweight since press on pulley's are more than worthless.
  2. #2 Re: plugs
    Portland Oregon
    Who said I was putting it on before the SSAC headers, and custom tune? And that's on top of my current supporting mods.
  3. #3 Re: plugs
    Joliet, IL
    i have been taking it easy since those pulls for sure i have my aero annuciator set to blink if my kr reads anything but zero....so that way i let off instantly....
    hey guys heres something weird i noticed today while investigating....is it just me or is this order of numbers on my coils not seem right can someone take a pic of theirs and or check if its the same it seems off or wrong to me...
    i redid the number for easier visibilty....btw new wires are in with no prevail still problems...
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  4. #4 Re: plugs
    May 2008
    staten island,NY
    the coil packs do not go in numerical order. stop beating on it with so much kr. drive it easy till you can touch the tune
  5. #5 Re: plugs
    Joliet, IL
    Quote Originally Posted by QwikGT View Post
    i took off the SC belt to insure my lead foot doesnt cost me my motor....runs like a champ with no boost...none of these problems exist with no boost.....L67 is a fukkin pig with out it tho
    00 Silvermist GTP
  6. #6 Re: plugs
    Wow...your beating on it now with no S/C belt...that's got to be good for it too...you know what you need to do is go buy a Honda and drive it on the daily and give your poor car a break.
  7. #7 Re: plugs
    Joliet, IL
    not beatin on it just eliminating my boost addiction i have been taking it real easy, grandma style ever since i saw 12.5* on my aero i about shyt myself...every time i get a spike that huge i hear a big pop ever since that pop i havent got on it or into i boost i refuse to unless i can scan with a tuner and fix my shyt i dont understand how my knock can be that high.....and the fact that there is a pop makes me think its def no false....maybe spark plug blow out....im at a loss i wont know until i can pull some timing and add fuel possibly....
    00 Silvermist GTP
  8. #8 Re: plugs
    Joliet, IL
    when looking at the motor im assuming cylinder order goes as so....
    bottom left cylinder is cylinder 1 and top left is cylinder 2....and so following that order like this below....view is from standing in front of the car looking into the engine bay....
    2 4 6
    1 3 5
    00 Silvermist GTP
  1. Crankshaft Position Sensor Replacement [*]
    By SyntheticShield in forum How To Write-Ups/Tech Tips
    Last Post: 11-23-2014, 12:54 AM
  2. cam position sensor
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2009, 02:16 PM
  3. Trouble History With Crankshaft Position Sensor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 12-23-2008, 09:43 PM
  4. HELP Crank Position Sensor
    By catcamvegas in forum General Tech Discussion
    Last Post: 08-02-2008, 10:30 AM
  5. crank position sensor
    By vermsta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2008, 02:41 PM
