Thread: cam position sensor
Results 1 to 2 of 2
  1. #1 cam position sensor
    SE Level Member runn141's Avatar
    Nov 2008
    ohio
    im in the process of changing head gaskets on a 3800 series 2. ive been told not to bother or remove the cam position sensor. can anyone post a pic of this on and off the motor? and where its located on the motor? and if this is removed what has to be done to retime the motor?
  2. #2 Re: cam position sensor
    Barksdale AFB, LA
    It's either on the front cover or inside it. If you're doing head gaskets you won't even touch it.
    2009 Subaru Impreza WRX STI
  1. Crankshaft Position Sensor Replacement [*]
    By SyntheticShield in forum How To Write-Ups/Tech Tips
    Last Post: 11-23-2014, 12:54 AM
  2. Trouble History With Camshaft Position Sensor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 06-04-2009, 01:21 PM
  3. Trouble History With Crankshaft Position Sensor
    Last Post: 12-23-2008, 09:43 PM
  4. HELP Crank Position Sensor
    By catcamvegas in forum General Tech Discussion
    Last Post: 08-02-2008, 10:30 AM
  5. crank position sensor
    By vermsta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2008, 02:41 PM
