you can use the one thats on there if its not broke there's no need to buy any..and if your going to bleed the line start when the car is cold..after you in stall your t-stat and your all hooke up and fulled up remove that bronze screw and then start the car and let it run and let the t-stat open and close a few times that should get all the air out..good luck!!
