Thread: Thermostat!????
Results 1 to 5 of 5
  1. #1 Thermostat!????
    Donating Users fratzke7's Avatar
    Waterloo, IA
    What brand Tstat is everyone running? I have a 160* now from my Dad's parts store and my car seems to still run a bit warm?
    ZZP 3.1 MPS, 2.5" catless exhaust, TOG's, XP hot cam, 105# springs and mod'd retainers, ZZP pcm, alt voltage booster, Wizaired intake, heads lightly ported and 3 angle valve job, PRJ 10.4's, ummm
  2. #2 Re: Thermostat!????
    you cant just put a 160* in it and expect it to work. you need to change the fan turn on points and what not.
  3. #3 Re: Thermostat!????
    Feb 2008
    What is "a bit warm?" AND How do you know that your car is running that temp?
  4. #4 Re: Thermostat!????
    Waterloo, IA
    I have all of that in my tune and my car seems to run about 175-190 on most days according to the scanner when I have it hooked up..even says so on my data logger?
  5. #5 Re: Thermostat!????
    Barksdale AFB, LA
    Unless you're cruising, it's going to run warmer. The car can only run so cool dependent on the weather.
    2009 Subaru Impreza WRX STI
  1. Thermostat went out got a question
    By jasonball in forum General Tech Discussion
    Last Post: 02-08-2009, 01:33 AM
  2. thermostat
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2008, 06:38 PM
  3. Thermostat
    By keenan00gtp in forum General Tech Discussion
    Last Post: 10-20-2008, 05:46 PM
  4. 180 thermostat
    By LMCOOK87 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2008, 03:00 AM
  5. What Thermostat Should I Get ?
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-10-2008, 07:00 AM
