Thread: Coolant fan only works with A/C on
Results 1 to 6 of 6
  1. #1 Coolant fan only works with A/C on
    SE Level Member bigwillie's Avatar
    Apr 2009
    Clinton Twp. Mich.
    98 Grand Prix SE 3.8. coolant fans only work when A/C is on. Common problem? Willie
  2. #2 Re: Coolant fan only works with A/C on
    SE Level Member Southern Yankee's Avatar
    Jan 2009
    Greenwood, SC
    Check the temp. sensor. Sometimes that is the problem, the fan comes on with the AC to allow it to cool the car while sitting.
  3. #3 Re: Coolant fan only works with A/C on
    Apr 2009
    Clinton Twp. Mich.
    Okay , thanks. Will
  4. #4 Re: Coolant fan only works with A/C on
    Apr 2009
    Clinton Twp. Mich.
    Quote Originally Posted by Southern Yankee View Post
    I got the car up to 210 and nothing happened, I then tapped on the temp sensor and the fans started working. Huh?
    Thanks for your help on this one. Hope the new sensor is cheap.
    Will
  5. #5 Re: Coolant fan only works with A/C on
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    your cooling fans should kick on around 210° if you dont have a reprogramed pcm
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  6. #6 Re: Coolant fan only works with A/C on
    Banned - Busted For Scamming
    Feb 2009
    its cheap. if you hooked a scanner too it, you would see the temperature probably reading something crazy low, thats why its not kicking the fans on. your gauge is gonna work though, since its a 3 wire sensor, one goes to the gauge, one goes to the computer.
  1. coolant fans only work when A/C is on
    By bigwillie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-26-2011, 07:14 PM
  2. Gas gauge works then doesn't...?
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 10-03-2008, 04:14 AM
  3. It Works!!!
    By 02BlueGT in forum PCM Tuning
    Last Post: 08-31-2008, 01:02 AM
  4. Finally! ABS Works again
    By Toofastgs in forum Brakes/Suspension/Chassis
    Last Post: 07-10-2008, 12:59 PM
